I recently got a pair of ratcheting pipe shears as I was sick of cutting pipe with a saw and then filing off burrs etc, slow and messy.
Only tested them so far as I have not had a job to use them given the current situation but in my testing I am having some trouble with them, they seem to crush the pipe out of shape and I am worried they won't form a good seal, especially if I was using them on 15mm pipe with push fit connections.
Am I doing something wrong? Seem pretty straight forward to use.
Ratcheting pipe shears
- Has thanked: 67 times
- Been thanked: 935 times
Dickie Dyer, not budget but not high end either. Says they are UK made though.
https://www.dickiedyer.com/en-GB/Plumbi ... ers/432848
- Has thanked: 32 times
- Been thanked: 637 times
ive got some think theyre rothenberger for 15mm pipe. they work sound for that but i can at a push cut up to 32mm waste pipe with em. but i have to sort of twist the pipe at the same time to get it going otherwise they will try to squash the pipe
for 40mm waste pipe i have one of them thats the same as a standard pipe slice dead easy to use that.
- Has thanked: 104 times
- Been thanked: 489 times
I use ratcheting cutters for 32 & 40mm waste pipe and like Fin need to twist at the same time. For 15mm & 22mm pipe I use a pair of JG pipe cutters, they have a much much sharper blade.
