Drill too wide
Mark-J
Has thanked: 81 times
Been thanked: 11 times
Drill too wide
Post by Mark-J »
I messed up. The drill is too wide for me to use on the wooden bracket below.
I was going to go for a 440mm extra-long drill bit but they are too expensive. I was then considering screwing by hand, but my wrists have a bit of arthritis so that's not really an option. I could use the drill at a tilt and screw in at a bit of an angle, but I don't really want to; not at least until I exhaust other possibilities.
This will do the job, yes?
www.screwfix.com/p/makita-ratchet-screw ... eces/2140r
Dave54
Has thanked: 1299 times
Been thanked: 1175 times
Drill too wide
Post by Dave54 »
Just to be clear, when you say "drill bit" you're talking about a screwdriver bit rather than a drill bit for drilling holes?
Have you got a quarter inch drive ratchet from a socket set and a converter to go to a hex bit?
That'll work if the screws not too tight.
Mark-J
Drill too wide
Post by Mark-J »
I'd need to make a pilot hole in the wood and then get the screw in there.
I'm thinking the above linked Makita ratchet set will work as far as getting the screw in, but I'm still going to have to make a pilot hole.
EDIT: Product description says it has a ¼" driver socket, ¼" magnetic bit holder
toolbox
Has thanked: 114 times
Been thanked: 200 times
Drill too wide
Post by toolbox »
Drill the bracket from behind before putting it up and use a long screwdriver with a rubber glove to improve your grip.
https://www.toolstation.com/search?q=long%20screwdriver
These users thanked the author toolbox for the post:
Mark-J (Tue Oct 29, 2019 12:54 pm)
Has thanked: 775 times
Been thanked: 3311 times
Drill too wide
What about a right angle attachment for your drill like this https://www.youtube.com/watch?v=Z3j_gLam-iw I bought one years ago to fit some cornice on kitchen cabinets, never used it again bit it is always there. About £7 on Ebay.
Dave54
Drill too wide
Post by Dave54 »
As toolbox says drill the bracket from behind. Again as he says a long screwdriver is best if your wrists will stand it. The trouble with the ratchet type is keeping enough pressure on, unless you use Torx head screws.
The other answer is something like this
https://www.screwfix.com/p/erbauer-angl ... 10mm/6746h
I see people saying that they have used it for driving screws.
ETA. DWD got there first!
These users thanked the author Dave54 for the post:
Mark-J (Tue Oct 29, 2019 12:56 pm)
Mark-J
Drill too wide
Post by Mark-J »
Hi Toolbox
I can't get at the bracket from behind. I've already made pilot holes in the wood, but there's no way to get through the grey portion (in the diagram).
Hi Dewaltdisney / Dave54
Those drill parts looks idea!
Thanks all :thumbleft:
Has thanked: 1413 times
Been thanked: 3991 times
Drill too wide
one of these https://www.screwfix.com/p/erbauer-magn ... 00mm/84662 will probably do it, cheaper than the other options as well
Mark-J
Drill too wide
Post by Mark-J »
^ Only problem is that it's too short by about 30mm. Otherwise I'd be using it.
Dave54
Drill too wide
Post by Dave54 »
Just add another "normal" bit holder to the end?
ETA. Thanks for the link to that long bit holder w~o. :thumbright: I've been meaning to get one of those for ages, and it's always "next time"
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1572 times
Drill too wide
Post by Job and Knock »
Ever seen an off line driver ?:
Trend Snappy SNAP_OFLD offline driver with quick chuck 001_01.jpg (42.64 KiB) Viewed 3321 times
Trend sell a decent quality one (seen above, in conjunction with a Trend Snappy Quick-Chuck - the gold item) and Kamasa do quite a decent one, too. Am alternative, although far less durable and less able to transmit huge amounts of torque, is the flexible driver:
Trend Snappy SNAP_FMD_1 flexible driver 001_01.jpg (54.04 KiB) Viewed 3321 times
which can get you out of some tight corners (or rather into them). For PZD screws I often just resort to using a 6in (150mm) or 12in (300mm) bit holder and driving the screw at a slight angle ("camming out"). This is a 305mm version from Milwaukee:
Milwaukee Shockwave Bit Holder 305mm 001_01.jpg (26.47 KiB) Viewed 3321 times
These users thanked the author Job and Knock for the post (total 2):
Dave54 (Sat Nov 02, 2019 7:31 pm) • Mark-J (Sun Nov 03, 2019 12:13 am)
Rating: 14.29%
Dave54
Drill too wide
Post by Dave54 »
Job and Knock wrote: Sat Nov 02, 2019 7:04 pm Ever seen an off line driver ?:
Not seen that. Cheers!
Not too badly priced either.
Mark-J
Drill too wide
Post by Mark-J »
Thanks for the advice
Bob225
Has thanked: 94 times
Been thanked: 857 times
Drill too wide
Post by Bob225 »
https://www.screwfix.com/p/flexi-bit-holder-300mm/3405v any good or https://www.screwfix.com/p/erbauer-angl ... 60mm/9929v
after 10 plus years i bit the bullet and got a right-angled cordless drill it make life so much easier
edit. Makita OFLD https://www.screwfix.com/p/erbauer-angl ... 60mm/9929v
