Masonry Paint over Oil-based paint
Gummo
Has thanked: 15 times
Post by Gummo » Fri Jun 28, 2019 1:21 pm
The front of my terraced-house has always been painted with oil-based gloss. I want to use a masonry paint instead - is this possible? If so, would a thorough abrasion with a wire brush suffice to key the surface?
Also, would you recommend, Sandtex, Johnstone's or Dulux?
wickedwjc
Has thanked: 30 times
Been thanked: 13 times
Post by wickedwjc » Thu Aug 22, 2019 9:56 am
No expert but my guess is it's not gonna work unless all the existing oil based paint is removed.
It's called masonry paint as it's designed to go onto masonry - if you put it onto something else (i.e. on top of oil based paint) then it probably won't adhere to the surface or dry properly and therefore won't last very long. Probably not what you want to do but could you use the same type of paint again? Alternatively you could use chemicals to remove the existing and get back to the original masonry.
These users thanked the author wickedwjc for the post:
Gummo (Thu Aug 22, 2019 9:29 pm)
Desmondo15
Has thanked: 263 times
Been thanked: 297 times
Post by Desmondo15 » Thu Aug 22, 2019 10:14 am
You just need an adhesion primer first then crack on.
These users thanked the author Desmondo15 for the post:
Gummo
Post by Gummo » Thu Aug 22, 2019 6:14 pm
Someone's recommended Zinsser Bullseye 123 - it claims to be paintable, without sanding, over almost anything. I'm going to sand and try it before masonry paint.
I'll let you know how it goes.
Desmondo15
Post by Desmondo15 » Thu Aug 22, 2019 8:48 pm
Give it several days to fully adhere, think it says 7 from memory.
Gummo
Post by Gummo » Thu Aug 22, 2019 9:29 pm
Will do - thanks.
Gummo
Post by Gummo » Mon Aug 26, 2019 7:27 pm
Well, I Zinssered it on Friday and applied two coats of masonary paint on Sunday. Everything went like a dream - I'm mightily relieved.
Thanks for your help.
