Hi all,
Had my garden returfed about 2.5 weeks ago. Had been watering it twice a day for the first 2 weeks, being the third week I am now watering it every alternate day. The grass has grown well about 10-12cm. I have a few questions if someone can help me out.
1) The grass now seems well rooted do I now still water it for the same amount of time as i was doing in the first two weeks?
2) I should be about to mow for the first time in the next few days, but was just wondering if i need to rake the lawn first to straighten the grass as where i have walked over the lawn the grass seems to lay flat (see photo).
3) Is it ok to mow when the grass is wet or should i let it dry first?
4) Do i need to water the lawn soon after it has been mowed?
5) I understand that the mower needs to be set at the highest, do i mow ever other day to get it to the required grass lenght?
Any advice will be much appreciated.
New Turf Care.. Advice needed.
- Has thanked: 139 times
- Been thanked: 112 times
Unless it's central court Wimbledon, lawn requires minimum care. They say lawn will need watering if they are used to so best not water.
I doubt new lawn requires raking so soon.
Not sure why highest setting when mowed, I would use middle and defo not the lowest.
I am no expert so wait for more replies.
- Has thanked: 18 times
Been told by the landscaper and even read it on different site that new turf require a lot of water to get the roots bedded (atleast twice a day in the first 2 weeks and every other day in week 3 and 4).yartin wrote: ↑Tue Aug 13, 2019 10:51 am Unless it's central court Wimbledon, lawn requires minimum care. They say lawn will need watering if they are used to so best not water.
Dead Leaves from near by trees have fallen onto the lawn and then if a big patch is flat, don't want the mower to grab the whole patch and make it bald from there, hence I asked if its a good idea to rake it first.
- Has thanked: 42 times
- Been thanked: 2484 times
No harm in raking it first.
Never cut the grass when its wet.
- Sean2012 (Thu Aug 15, 2019 11:07 am)
