Removing grime wooden stair rails
mawallace
Has thanked: 1 time
Post by mawallace » Sun Aug 11, 2019 12:47 pm
Our wooden stair rails are vanished but look very dirty and are sticky.
I think its years of grease from hands and the previous occupant who smoked.
Is there a way of getting rid of the stuff as i would like to apply a new layer of stain or varnish
someone-else
Has thanked: 32 times
Been thanked: 1609 times
Post by someone-else » Sun Aug 11, 2019 1:21 pm
Yes there is, but it depends on what is actually on the stairs, short of analysing it you will have to use trial and error to see what works best.
I would suggest you don't use too much friction such as a wire brush as it may heat up the whatever it is and cause it to turn to "goo" and become worse.
I would try starting off with elbow grease and sugar soap solution.
Fret not, a forum is a collection of opinions. Above, are mine.
Which is correct? Metre or Meter? Click the link to find out more.
Working on anything electrical? have you got a multi meter? why not? Would you hit a nail with a shoe?
If gloom had a voice, it would be me. :mrgreen:
:idea1: How to post a picture on this forum Click here
moderator2
UHM Super Moderator
Has thanked: 145 times
Been thanked: 469 times
Post by moderator2 » Sun Aug 11, 2019 5:41 pm
Better asked in Painting and Decorating. I'll move it.
Has thanked: 470 times
Been thanked: 1769 times
Post by dewaltdisney » Sun Aug 11, 2019 6:07 pm
Start with Methylated spirits for a clean down. It removes grease but it will not soften the varnish causing delamination issues. If you are going to paint them white, which will brighten the area and give it a fresh clean look see my link below
Bob225
Has thanked: 59 times
Been thanked: 712 times
Post by Bob225 » Mon Aug 12, 2019 11:48 am
Hot soappy water (a few drops of washing up liquid) and some effort
OchAye
Has thanked: 836 times
Been thanked: 962 times
Post by OchAye » Mon Aug 12, 2019 9:43 pm
They are dirty because they have been used, they are sticky because the last coat of varnish or whatever it was is disintegrating.
Correct on the first part but the second part is irrelevant. You will find you will cause as much damage even if you don't smoke but you use cream for your hands, face etc. or you simply have greasy sweaty hands.
I would go with all the comments mentioned above but I would use meths at the last last wipe/scrubb. Make sure you rinse off any detergents you use before you get to the methylated spirit. You might as well use some green Scotch-Brite (there are other more abrasive colours) whilst you clean so you key the surface at the same time. :-)
54aardvark
Has thanked: 12 times
Been thanked: 56 times
Post by 54aardvark » Thu Aug 29, 2019 2:07 pm
This stuff is excellent, had a freebie from Decorating Direct and its now my go-to for this sort of thing.
https://www.decoratingdirect.co.uk/view ... DEGREASER/
There are no problems - only solutions
