Workshop Vac
Blakey
Has thanked: 181 times
Been thanked: 46 times
Workshop Vac
Post by Blakey »
Hi All,
My old Draper DWE1400 vacuum cleaner has finally gone to a better place.
so i'm looking to replace it, the Draper vacuum that supersedes it WDV50SS doesn't have great write ups? , I am a DIY'er not a pro, so don't need anything top of the range, just something that will clear up sawdust etc in the garage/workshop £250ish.
all/any advice greatly appreciated.
You're never too old to learn something stupid.
someone-else
Has thanked: 24 times
Been thanked: 1760 times
Re: Workshop Vac
Post by someone-else »
Henry
Fret not, a forum is a collection of opinions. Above, are mine.
Working on anything electrical? have you got a multi meter? why not? Would you hit a nail with a shoe?
If gloom had a voice, it would be me. :mrgreen:
:idea1: How to post a picture on this forum Click here
Video of how to resize / rotate pictures can be found on This page
Rorschach
Has thanked: 53 times
Been thanked: 873 times
Re: Workshop Vac
Post by Rorschach »
I got 7 years of really dirty hard graft from a lidl vac, it still works now but it whines a lot so I keep it for really mucky work out in the garden or in the loft. I replaced it with another lidl vac about 2 years ago, another great bit of kit.
They cost about £60, well worth the money.
Blakey
Argyll
Has thanked: 940 times
Been thanked: 354 times
Re: Workshop Vac
Post by Argyll »
Blakey
jaeger
Has thanked: 35 times
Been thanked: 70 times
Re: Workshop Vac
Post by jaeger »
That seems a hefty price for Draper, possibly the most expensive thing I've seen from them.
No longer sold but I have an Earlex I paid about £70 for years ago and that's seen some abuse
and still going, rubble, water and dust extractor for sanding now you've got me looking at vacs
I'm not sure what I'd buy if mine packed up.
These users thanked the author jaeger for the post:
Blakey
boxedin
Has thanked: 61 times
Been thanked: 319 times
Re: Workshop Vac
Post by boxedin »
How long is a piece of string really need to pin down your spec
Capacity, Wet and dry, Blower facility, Power takeoff, (inc max watts), Cable length, hose length, Noise level, Filtration level,Connectivity to power tools (adapters etc). Drainage valve, Use in conjunction with a centrifuge ?
These users thanked the author boxedin for the post:
Blakey
sammy.se
Has thanked: 63 times
Been thanked: 65 times
Re: Workshop Vac
Post by sammy.se »
I recommend using some of your budget to make or buy a cyclone. I made one out of cheap bits and its really great for quick emptying and keeping suction power consistent. Very useful for larger wood particles, e.g. router and planer.
Sent from my Nexus 5X using Tapatalk
These users thanked the author sammy.se for the post:
Blakey
Bob225
Been thanked: 752 times
Re: Workshop Vac
Post by Bob225 »
The newer henry's seem under powered, i have one that 9-10 years old, i have just replaced the on/off switch and that all its asked for
Nilfisk make some good bits of kit but there not cheap
Blakey
boxedin
Re: Workshop Vac
Post by boxedin »
sammy.se
jaeger
Re: Workshop Vac
Post by jaeger »
[quote="Bob225"]The newer henry's seem under powered, i have one that 9-10 years old, i have just replaced the on/off switch and that all its asked for
Think they are, the EU Banned vacuum cleaners over 900 watts in 2017, didn't the old Henry's used to have a high/low switch too?
I believe thought that this ban only applies to domestic units.
Bob225
Re: Workshop Vac
Post by Bob225 »
yes mine is has the neon switch for hi/low (green power switch) - thay got around that eu law by using the word "Industrial"
jaeger
Re: Workshop Vac
Post by jaeger »
Bob225 wrote:yes mine is has the neon switch for hi/low (green power switch) - thay got around that eu law by using the word "Industrial"
Bit like the 100 watt bulb....... "For industrial use only"
Blakey
Re: Workshop Vac
Post by Blakey »
Thanks for all replies and advice,
I have looked at the Hushpower, and the reviews are great, also looked at the Fein and that seems a nice piece of kit, Fein £250, Hushpower £99, always been a believer that you get what you pay for ??, but now thinking would i be paying for the name, also looked at small festool :dunno:
Old vac took a lot of abuse over the last 10/15 years picking up wood chippings, dust, small rubble wallpaper and much more, the power takeoff was great for connecting tools, never had cause to use for sucking up water.
fin
Has thanked: 32 times
Been thanked: 585 times
Re: Workshop Vac
Post by fin »
i found a henry in a skip a year ago. plugged him in and he was broke. stripped his motor apart and checked for continuity on the power lead first. (id obv checked the fuse first) one of either the live or the neutral obv i suppose was broken. it turned out to be at the plug end. so i just cut it off and hoyed my own on and hes grafting like a goodun. pretty sure he is about 20 years old aswell.
These users thanked the author fin for the post (total 2):
ArgyllBlakey
Rating: 14.29%
Cannyfixit
Has thanked: 88 times
Been thanked: 165 times
Re: Workshop Vac
Post by Cannyfixit »
Bob225 wrote:The newer henry's seem under powered, i have one that 9-10 years old, i have just replaced the on/off switch and that all its asked for
That true,ours died after ten years and the Mrs immediately bought another before I had chance to have a look,turned out it had just broken the cable,rewired a new flex on and wham bam I have a shop vac lol
The difference between old and new is noticeable
These users thanked the author Cannyfixit for the post:
Blakey
Return to “Tool Talk”
