Workshop Vac
- Blakey
- Has thanked: 247 times
- Been thanked: 48 times
Workshop Vac
Hi All,
My old Draper DWE1400 vacuum cleaner has finally gone to a better place.
so i'm looking to replace it, the Draper vacuum that supersedes it WDV50SS doesn't have great write ups? , I am a DIY'er not a pro, so don't need anything top of the range, just something that will clear up sawdust etc in the garage/workshop £250ish.
all/any advice greatly appreciated.
You're never too old to learn something stupid.
- Has thanked: 42 times
- Been thanked: 2483 times
Re: Workshop Vac
Henry
- Has thanked: 99 times
- Been thanked: 1022 times
Re: Workshop Vac
I got 7 years of really dirty hard graft from a lidl vac, it still works now but it whines a lot so I keep it for really mucky work out in the garden or in the loft. I replaced it with another lidl vac about 2 years ago, another great bit of kit.
They cost about £60, well worth the money.
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
- jaeger
- Has thanked: 40 times
- Been thanked: 76 times
Re: Workshop Vac
That seems a hefty price for Draper, possibly the most expensive thing I've seen from them.
No longer sold but I have an Earlex I paid about £70 for years ago and that's seen some abuse
and still going, rubble, water and dust extractor for sanding now you've got me looking at vacs
I'm not sure what I'd buy if mine packed up.
- Has thanked: 61 times
- Been thanked: 319 times
Re: Workshop Vac
How long is a piece of string really need to pin down your spec
Capacity, Wet and dry, Blower facility, Power takeoff, (inc max watts), Cable length, hose length, Noise level, Filtration level,Connectivity to power tools (adapters etc). Drainage valve, Use in conjunction with a centrifuge ?
- Has thanked: 88 times
- Been thanked: 79 times
Re: Workshop Vac
I recommend using some of your budget to make or buy a cyclone. I made one out of cheap bits and its really great for quick emptying and keeping suction power consistent. Very useful for larger wood particles, e.g. router and planer.
Sent from my Nexus 5X using Tapatalk
- Has thanked: 94 times
- Been thanked: 857 times
Re: Workshop Vac
The newer henry's seem under powered, i have one that 9-10 years old, i have just replaced the on/off switch and that all its asked for
Nilfisk make some good bits of kit but there not cheap
- jaeger
Re: Workshop Vac
[quote="Bob225"]The newer henry's seem under powered, i have one that 9-10 years old, i have just replaced the on/off switch and that all its asked for
Think they are, the EU Banned vacuum cleaners over 900 watts in 2017, didn't the old Henry's used to have a high/low switch too?
I believe thought that this ban only applies to domestic units.
- jaeger
Re: Workshop Vac
Bit like the 100 watt bulb....... "For industrial use only"Bob225 wrote:yes mine is has the neon switch for hi/low (green power switch) - thay got around that eu law by using the word "Industrial"
- Blakey
Re: Workshop Vac
Thanks for all replies and advice,
I have looked at the Hushpower, and the reviews are great, also looked at the Fein and that seems a nice piece of kit, Fein £250, Hushpower £99, always been a believer that you get what you pay for ??, but now thinking would i be paying for the name, also looked at small festool
Old vac took a lot of abuse over the last 10/15 years picking up wood chippings, dust, small rubble wallpaper and much more, the power takeoff was great for connecting tools, never had cause to use for sucking up water.
- Has thanked: 32 times
- Been thanked: 786 times
Re: Workshop Vac
i found a henry in a skip a year ago. plugged him in and he was broke. stripped his motor apart and checked for continuity on the power lead first. (id obv checked the fuse first) one of either the live or the neutral obv i suppose was broken. it turned out to be at the plug end. so i just cut it off and hoyed my own on and hes grafting like a goodun. pretty sure he is about 20 years old aswell.
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
Re: Workshop Vac
That true,ours died after ten years and the Mrs immediately bought another before I had chance to have a look,turned out it had just broken the cable,rewired a new flex on and wham bam I have a shop vac lolBob225 wrote:The newer henry's seem under powered, i have one that 9-10 years old, i have just replaced the on/off switch and that all its asked for
The difference between old and new is noticeable
- These users thanked the author Cannyfixit for the post:
- Blakey
