Fixing battons to floor joists
- Been thanked: 3 times
Hello all. Joined this forum as a long time observer. Thought it was about time as got many a useful tip!
I’ve recently been patching some floorboards in our bedroom as they creaked like hell and we’re chopped up worse than Texas Chainsaw Massacre.
Anyway, after putting the new boards down, I wanted to give the new boards some extra surface to join to as the way some of the existing boards had been cut didn’t Alli much room on the width of the joist for the new board.
I’ve fixed some 44mm x 44mm baton with a 4mm screw to the side of the joist running parallel with it in places where it’s needed.
Anything wrong with this? I’ve only done one of the bedrooms so far and others are going to need the same treatment so thought I’d better check!
TIA.
TIA.
- Has thanked: 247 times
- Been thanked: 208 times
Re: Fixing battons to floor joists
Nope, perfectly acceptable to do
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Awesome, thanks for the reply.
I’ve been trying to fix the battons between 200/300mm centres. Is that about right?
Also where I’ve replaced a long length of floor board I’ve put fixings in the batton and joist that it attaches to, nothing wrong with that is there?
The main thing I was a bit nervous about was weakening the joists as there will obviously be some leverage applied by the batton fixings. The joists are a combination or 44mm wide and about 70ish mm.
It’s certainly made the floor feel more solid and creaks a whole lot less!
There's nothing wrong with what you've done.
It's all good
It's all good
Another question if you please following on from my original post. I just wanted to check it was safe to use screws to fix the new boards down above where the joists have been drilled for cables.
It looks like some of the existing boards have been fixed using nails above where the joist has been drilled.
Presumably I’m ok using the existing nail holes and in a slightly wider and shorter screw so it grips?
My OCD has gone into over drive seeing all the joists chopped up near notching for pipes and hole cut outs for cables. sh*t myself even putting the small screws in around these bits of the joists.
I’m going to have a lie down!
Yes, I always refix using screws. So much easier for future access. Make sure you're free of any pipes and cables.
If floorboards are going to be covered it's always good practice to mark any pipe and cable runs on them to help future maintenance.
