Stair treads
- Has thanked: 2 times
Stair treads
Hello
I have a job to make some stair treads. That normally means no issue but these are solid oak treads at 100mm thick and 235mm wide and roughly 800mm long. They will be put in between two steel U section strings my question is can I fit oak at that size and thickness tight in between these strings or do i need to leave and expatiation gap and if so how much of one for each side?
Also what could the effect be to the treads if fitter tight and they did expand ?
Thanks Jack B Carpentry
- Has thanked: 731 times
- Been thanked: 2303 times
Re: Stair treads
heeelllooo and welcome J.B.Carpentry
tannin in the oak will cause black staining and rust the steel so not a good combination unless stainless steel
Re: Stair treads
big-all wrote:heeelllooo and welcome J.B.Carpentry
Yes I understand this the steel with be sealed with paint to stop the tannin effecting the steel and we are considering stainless steel to sit the wood on
Re: Stair treads
you could use brass or zinc as spacing
but dont forget all bolts or fixings must also be oak freindly
wood wont expand along its length so 3-5mm expansion each end is more than enough to allow the metal to move
are you remembering you need no gap greater than 95[100]mm in the riser assuming open ??
- These users thanked the author big-all for the post:
- J.B.Carpentry
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Re: Stair treads
That staircase in my avatar is all steel. The oak treads (about 25mm thick) were fixed down using rubber grommets beneath the screws to ensure that there is minimal timber to steel contact, the screws the themselves were A2 stainless steel countersunk and pelleted and the steel was coated with an intumescent paint before it was finished with what smelled like an epoxy paint. We fixed with two screws at either end of the treads leaving about 3mm at each end of the treads (no more than that needed, really, as timber tends to expand and contract across the grain more than along the length) but the oak was sealed with 4 coats of Sadolin before installation and we didn't cut any to length ourselves.
- J.B.Carpentry
Re: Stair treads
we are currently undecided with the riser if its kept open or we put something there but i do understand the regulations don't allow anything bigger than 99mmbig-all wrote:you could use brass or zinc as spacing
- Job and Knock
Re: Stair treads
The regs say 100mm AFAIK. The stuff in my avatar had a solid steel riser, but I've also installed where the riser was glass (laminated)J.B.Carpentry wrote:we are currently undecided with the riser if its kept open or we put something there but i do understand the regulations don't allow anything bigger than 99mm
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Stair treads
The actual wording is along the lines of:- "A 100mm sphere must not be able to pass through any part of the staircase"Job and Knock wrote: The regs say 100mm AFAIK.
Re: Stair treads
thats why i aim for 95mm as wood movesayjay wrote:The actual wording is along the lines of:- "A 100mm sphere must not be able to pass through any part of the staircase"Job and Knock wrote: The regs say 100mm AFAIK.
- Job and Knock
Re: Stair treads
...and why we have a 100mm rubber ball to check (same as the BCO might have). If you need to squeeze it just a bit to get it through then you're OK. TBH I've rarely come across a BCO who's so pedantic that he'd jump up and down about 2mm - in the case of steel staircases you've got far greater problems to deal with getting the treads level side-to-side and front-to-back as well as with an even rise between treads. The last one I did, in fact four separate rises, was all over the show when we started and made worse by the attempt to weld several tons of ballasting onto the stringers of the longest section to damp the bounciness which it had. I needed to level off each and every tread on the four flights. Reckon that welding all the extra steel must have twisted the whole lot
