Pole chainsaw
- Has thanked: 855 times
- Been thanked: 994 times
Pole chainsaw
Would this chainsaw be worth bothering with?
https://www.screwfix.com/p/titan-ttb426 ... uner/99641
I have an overhanging branch about 4-5 feet long and 3-4 inches thick that I need to chop. I could probably cut the branch in two using my standard chainsaw + ladders (against the branch) + someone on site to call the ambulance. The thing at Screwfix would manage the smaller branches to reduce the bulk of what has to come down but it does not seem worth bothering for just pruning. Any ideas if it could manage a 3-4 inch branch taking plenty of time to cut it?
- Has thanked: 1299 times
- Been thanked: 1175 times
Re: Pole chainsaw
Dunno about that one. I'd have thought it would do it easily although I've only used a mains "ordinary" chainsaw a couple of times I was impressed.
What about one of these though?
https://www.screwfix.com/p/telescopic-tree-pruner/2096f
I bought one similar from Lidl for the lopper, but I tried the saw last year on a couple of branches to save getting the petrol pole saw out. Saw works well on 3" sort of stuff. Someone there in the reviews says they were cutting 3-4" stuff as well.
- Has thanked: 99 times
- Been thanked: 1022 times
Re: Pole chainsaw
If it's a one off job, get a pole saw, much cheaper. Yes it will be a bit slow and harder work, but pretty safe and you only have to do it once.
Re: Pole chainsaw
Thank you Dave54 for the hand pruner. I had missed that as I had found the same bahco ones costing as much as the electric gadget.
Rorschash, yup at that price too (must double check the height tomorrow). If the main branch if clear from other growth I can take down safely with the electric chainsaw.
- Has thanked: 94 times
- Been thanked: 857 times
Re: Pole chainsaw
I have the ryobi pole chainsaw fully extended its very top heavy, the trigger is right on the end, what makes it a pita to balance and use and put any pressure on the saw
ladder + bow saw if you can manage it, or get some idiot in a van to do it
Edit. The titan is the same design as the ryobi
Re: Pole chainsaw
FWIW I have used jubilee clips to hold a hand pruning saw onto a long pole for this kind of work. Didn't cost me anything and got the job done, if a little slowly lol.
- Has thanked: 199 times
- Been thanked: 482 times
Re: Pole chainsaw
Reading through this thread that was in my mind as it's something I've done the same myself although I may have used tape. Done the same with a paint brush once too painting a really hard to get to downpipe.Rorschach wrote:FWIW I have used jubilee clips to hold a hand pruning saw onto a long pole for this kind of work. Didn't cost me anything and got the job done, if a little slowly lol.
Re: Pole chainsaw
You do what you gotta do to get the job done. I also have to paint an awkward spot once, I cut the paintbrush and glued and screwed it back onto the handle at 90deg, worked a charm but was a bugger to dip into the paint lol.Grendel wrote:Reading through this thread that was in my mind as it's something I've done the same myself although I may have used tape. Done the same with a paint brush once too painting a really hard to get to downpipe.Rorschach wrote:FWIW I have used jubilee clips to hold a hand pruning saw onto a long pole for this kind of work. Didn't cost me anything and got the job done, if a little slowly lol.
Re: Pole chainsaw
Howdy, follow on to the the scroofix handheld telescopic pruner has done the trick and I have removed all minor branches. It has a rather wobbly saw blade, I am surprised I have not broken it yet, the secateurs are better than I expected, and it untightens and folds at will. Worth the money.
Given I am too lazy to get the ladders out, I will try cutting the main 3" branch with it next.
- Has thanked: 2 times
- Been thanked: 76 times
Re: Pole chainsaw
I have used a similar one to trim our Chestnut tree, I managed to cut some fairly thick branches 100/160mm, however I forgot one very important thing and that was gravity so first time, lots of sawdust and a branch on the head lesson learnt. Nos
Re: Pole chainsaw
The saw on mine is pretty wobbly too. Same on I suspect. Works OK though, and seems a lot tougher than it feels.
I always wear a helmet and when I'm doing those jobs.
Re: Pole chainsaw
Dave54 wrote:The saw on mine is pretty wobbly too. Same on I suspect. Works OK though, and seems a lot tougher than it feels.
Re: Pole chainsaw
Not quite, but better to be a bit over careful than have a large branch plant itself in the top of your head!Bob225 wrote:Dave54 wrote:The saw on mine is pretty wobbly too. Same on I suspect. Works OK though, and seems a lot tougher than it feels.
