Loctite vs Super Glue?
yadnom1973
Has thanked: 8 times
Been thanked: 2 times
Post by yadnom1973 »
Looking at fixing a threaded stud into a handle and I was going to use Loctite Red but the guy at the shop was going to use Super Glue. I always took Loctite Red as pretty much the last word in bonding threads as long as there was no heat involved, go knows it’s given me enough misery trying to undo them. I don’t really know anything about how super glue would behave?
So I was wondering what people out there normally turn to for a permanent fix of a stainless steel thread?
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: Loctite vs Super Glue?
Post by ayjay »
With a simple Cyanoacrylate glue (super glue) setting in ten seconds (or less) it sounds less than ideal if you have to wind something onto a thread before the glue has set.
Loctite Red takes up to 24 hours to set completely so might not be ideal if you want to use the handle soon afterwards, a rapid set epoxy might be a better alternative, you'll get five to ten minutes working time and not too long for a full cure.
yadnom1973
Hi, ayjay. Thanks for the help. Working time is not an issue. It can be done in 10 seconds if need be though a little tricky. Or it can be left to cure for however long it takes the only issue for me is which will make the strongest bond? It’s an item that is stored indoors but has intermittent out door use, could get wet if the weathers bad but not expected to be submerged for any period of time beyond being dropped in a pond or something then retrieved. Will be expected to put up with the harshest exterior conditions when in use. I’ll put a spring pin through the shaft and collar also but I was just surprised that he preferred Super Glue and was wondering if other people reached for this before the Loctite also and why? I’d not thought of epoxy ether, you think it would be stronger than Loctite?
Dave54
Has thanked: 1299 times
Been thanked: 1175 times
Post by Dave54 »
Permanent fix I'd usually go for Loctite red, although blue will be pretty permanent for most things.
No luck with using superglue here.
You can heat the thread to 250C (IIRC) to remove any fasteners where Loctite has been used, assuming nothing else will be damaged of course.
ayjay
Post by ayjay »
Dave54 wrote:Permanent fix I'd usually go for Loctite red, although blue will be pretty permanent for most things.
I think the blue is removable with hand tools but the red needs heat as well. I'd use epoxy cos I always have some of that, but I'm sure the red loctite will work just as well, it is what it's designed for when all's said and done.
Dave54
Post by Dave54 »
Agreed, the blue is removable, but it still makes things pretty tight to get off.
The red stuff I've got is "Studlock" it's ages old but still works. Apparently it's OK to use after the expiry for "non critical" stuff.
yadnom1973
I think Loctite it the way to go I was jusy wondering if I was missing a trick there.
Rorschach
Has thanked: 99 times
Been thanked: 1022 times
Post by Rorschach »
Superglue is probably about as effective as blue loctite.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Loctite is the proper thing... wouldnt have even thought about superglue when there is a readily available specific product....
Stainless threads.... half the time they gall up anyway :lol: If you dont lubricate them anyway.
Nos
Has thanked: 2 times
Been thanked: 76 times
Post by Nos »
I personally would use Loctite however superglue is available in different setting times I use a lot of "60 sec" on the models I build, it does what it say on the tube :wink: Nos
Jonno34
Post by Jonno34 »
Loctite either blue or red though red will be harder to release
Return to “General DIY forum”
