Location for bathroom extractor fan
- Has thanked: 9 times
I have a small bathroom in the back addition of a terraced house and am wondering where's the best location for an extractor fan. On the left wall at the end of the bath, or on the end wall & higher up. Or does it matter?
- DSC_1802.JPG (143.98 KiB) Viewed 2131 times
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Location for bathroom extractor fan
The act of the extractor in withdrawing air from your bathroom requires that that air is replaced from somewhere.
Put it next to an open window and you'll create a perfectly useless current of air circling between the two - I'd opt for a position which is well away from where the air will be drawn in and try and make any source of steam be on that route.
I agree, I've lived in the house for 25 years and never had a problem with mould etc as I've always cracked the window open. I'm now looking at renting it out so it comes down to whether the tenant bothers to open the window or not. Maybe your example of 'a useless current of air circling between the two' would be better than no ventilation at all if the door & window are both closed?
- Has thanked: 1413 times
- Been thanked: 3988 times
If it were me I'd install an inline fan in the loft. Screw down a board with a tap washer at each screw point.. then fit the inline fan to the board again using tap washers. This will minimise vibration and therefore noise. (noise is the main reason tenants won't switch on fans)
Vented via the soffit with the inlet in the ceiling.
This sorta thing https://www.screwfix.com/p/manrose-in-l ... 00mm/41379
Then the vent can be fixed directly over or adjacent to the shower.
- Cantseeitfrommyhouse
- Has thanked: 36 times
- Been thanked: 108 times
wine~o wrote:If it were me I'd install an inline fan in the loft. Screw down a board with a tap washer at each screw point.. then fit the inline fan to the board again using tap washers. This will minimise vibration and therefore noise. (noise is the main reason tenants won't switch on fans)
Hide the Isolator as well. And write it into their tenancy agreement that if the little twunts turn it off they can be shot in the face.
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
No tenant if mine every opens a window, especially in the bathroom. I would get a good extractor fan surf a trickle feature, over run and humidistat.
Will save you money in the future.
Mental ... go to the website and put 41379 in the search box.davej wrote:Thanks, for some reason the Screwfix site won't display properly for me, regardless of which browser I use. Strange, not had that before.
