Fan in a bathroom is not working. I haven't checked anything and can't till tomorrow but would like some ideas as where to start.
The fan is 12V as says on the fan (low voltage, assume this is ac not dc?), transformer in the loft plus spur fuse.
I need to check the fuse first then if fan is faulty, would the transformer go faulty?
If output voltage at the fan shows around 12V ac on my multi-meter, is it enough to confirm transformer is working?
Extractor Fan not working
- Has thanked: 247 times
- Been thanked: 208 times
Re: Extractor Fan not working
If transformer isn't working there'll be 0v at the fan.
Sent from my HUAWEI VNS-L31 using Tapatalk
- Cantseeitfrommyhouse
- Has thanked: 36 times
- Been thanked: 108 times
Highly likely the transformer has turned it's toes up yes. All transformers are AC.
Equally likely is the fan motor/pcb itself.
And yes.
And yes.
- These users thanked the author Cantseeitfrommyhouse for the post:
- yartin
- Has thanked: 136 times
- Been thanked: 112 times
It was the transformer, the most awkward one but had to be replaced, all working and job done.
