DIY Forum
Ultimate Handyman Ultimate Handyman Ultimate Handyman Ultimate HandymanUltimate Handyman on Pinterest
DIY Forum/Home improvement advice forum
A-Z CONTENTS | DISCLAIMER | DIRECTORY | DIY VIDEO | HOME | SAFETY FIRST | FORUM RULES
It is currently Tue Feb 09, 2016 8:28 pm
Time zone: Europe/London
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
Author Message
 Post subject: soil vent
PostPosted: Wed Aug 31, 2011 10:05 pm
Offline
Has thanked: 11 times
Been thanked: 0 times
Hello again
Next problem…… I will be fitting/getting fitted, an upstairs shower room, fitting a new soil pipe down through floor, into cupboard, then under ground floor, out to manhole (which has connections available) in garden. I have to fit a roof tile vent in the upstairs shower room which has a 4” flexi pipe that is reduced to 3.5” at the bottom
My question is …. Would I be able to reduce this any more i.e. to 2” or would that be too little air, as I have a problem with getting a 3.5” pipe to the vent ??
p.s. , from vent to manhole would be about 12m
cheers
Share on FacebookShare on TwitterShare on DiggShare on DeliciousShare on Google+
Top
 Profile
You may not be able to see the full post including pictures unless you register or log in
 Post subject: Re: soil vent
PostPosted: Wed Aug 31, 2011 10:10 pm
Offline
Has thanked: 322 times
Been thanked: 3358 times
I'm confused. :scratch: What is the roof vent tile for.
What pipe do you want to reduce.
Top
 Profile
PostPosted: Wed Aug 31, 2011 10:35 pm
Offline
sorry,
i need to have a vent for the soil pipe for the wc and stuff, i think ??,
the only way it can be vented is a durgo or a roof vent, the shower room has the roof directly above it so the roof vent was a better option, the roof vent has a 3.5" flexi tail on it, which can be fitted in the slope of the roof, I need to connect the vent to the 4" under shower room floor, it would make life alot easier if i could connect in 2"
or maybe i dont need a vent ?????
does that make sense ??
i think i have confused myself :dunno: i need to lay off the Glen Fiddoch
cheers
Top
 Profile
PostPosted: Wed Aug 31, 2011 10:41 pm
Offline
Bushmills "Blackbush" is nice.
If you have an SVP elsewhere you could use a durgo.
If the vent is for an extractor then it needs to be 110mm.
Top
 Profile
PostPosted: Wed Aug 31, 2011 10:51 pm
Offline
the pipe would be inside a wall so im guessing a durgo is not an option,
there would be no other connections, pipe would run from the shower room to manhole, as far as i can see there is no other way to allow air into pipe other than the roof vent or the soil through roof with a tile flashing rubber thing. but i dont have 4" room in walls to put pipe,
:cb
Top
 Profile
PostPosted: Wed Aug 31, 2011 11:52 pm
Offline
You could go to 3" and fit a durgo provided the wall is vented
Top
 Profile
Display posts from previous:  Sort by
Similar topics
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Visit Langs Industrial
News News Site map Site map SitemapIndex SitemapIndex RSS Feed RSS Feed Channel list Channel list
ultimatehandyman privacy policy
Contact
Powered by phpBB® Forum Software © phpBB Group
phpBB SEO
