Customer of mine is having an extension built and the builder wants to finish in tape and joint rather than plaster
I know its quicker for the builder but what offers the best finish? even though its jointed is there still filling and sanding down to be done and is it rougher to look at when painted?
many thanks for any advice
Al
Plastered finish or tape and joint??
- Has thanked: 61 times
- Been thanked: 184 times
Shouldn't look rougher as long as the plasterboards are in good nick. There is a degree of sanding to be done after the final fill to smooth out the finish and make it flush with the board.
ah
ah
- 54aardvark
- Has thanked: 16 times
- Been thanked: 56 times
A lot of tape & fill here in Scotland, generally only get a full skim on old walls.
I do a lot of T & F myself, the advantage being that I can get started on the mist coat quite often within 24 hours (temperature/humidity allowing) rather than waiting 4 days plus for a full skim to dry out. If the plasterer knows what they're doing sanding is minimal and the finished seams impossible to distinguish. Even better if you can get the T&F done on a Friday and you can guarantee to have mist & at least one finish coat by Monday evening.
There are no problems - only solutions
- Has thanked: 2 times
- Been thanked: 76 times
Here in France almost all new builds are Dry lined, just make sure they use the correct boards, ours will be having three fills and sanding, so when painted should be as smooth as a babys bot! dont always expect skimmed (wet) to be any better, plastering is a very skilled job, it doesn't always end up smooth, have seen plenty that in the right light looks like corrugated iron.
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
What are the correct boards as a matter of interest? Do you mean the ones with the tapered edge?Nos wrote: ↑Mon Sep 30, 2019 6:54 am Here in France almost all new builds are Dry lined, just make sure they use the correct boards, ours will be having three fills and sanding, so when painted should be as smooth as a babys bot! dont always expect skimmed (wet) to be any better, plastering is a very skilled job, it doesn't always end up smooth, have seen plenty that in the right light looks like corrugated iron.
Yes, tapered. You can tape & fill square edge board but it means you need to taper out the join significantly to make it unnoticeable.Argyll wrote: ↑Thu Oct 10, 2019 9:59 amWhat are the correct boards as a matter of interest? Do you mean the ones with the tapered edge?Nos wrote: ↑Mon Sep 30, 2019 6:54 am Here in France almost all new builds are Dry lined, just make sure they use the correct boards, ours will be having three fills and sanding, so when painted should be as smooth as a babys bot! dont always expect skimmed (wet) to be any better, plastering is a very skilled job, it doesn't always end up smooth, have seen plenty that in the right light looks like corrugated iron.
I just finished boarding out a bedroom and used 1800x900 to make navigating the stairs and installing myself easier. I installed the boards horizontal so had the tapered edge horizontally and butt joins vertically.
ah
