Is Zinsser Bulls Eye good for stone sills
funkytwig
Has thanked: 2 times
Been thanked: 3 times
Post by funkytwig »
And do I need an undercoat? Its only 2 sills so don't need much and would rather have a combined undercoat.
Also what type of paint should I use? I have wooden frames as well so really want to use the same paint for wood and stone.
The prep I am doing is Nitromors to strip the paint then Polyfill wood hardener to treat the wood.
Desmondo15
Has thanked: 279 times
Been thanked: 327 times
Post by Desmondo15 »
You could go Zinsser Allcoat which is excellent on masonry and concrete. Self priming too.
funkytwig
Post by funkytwig »
Desmondo15 wrote: Thu Jul 09, 2020 8:13 pm You could go Zinsser Allcoat which is excellent on masonry and concrete. Self priming too.
Thanks but I think I need a primer that I can paint gloss on. I want the sill and wood to be the same colour. Even if I purchased two seperate paints the colours for maisinary paint are very limeted and the rest of the sills are burgandy so I want to keep with that.
Desmondo15
Allcoat gloss is self priming too. You can get it colour mixed.
