Two different speed ratings on same axle - is it an MOT fail?
udaman
Has thanked: 159 times
Been thanked: 17 times
Post by udaman »
Hi all
Just been told that it is, but wasn't aware and I'm sure it has passed like that before? Unless of course it was part of the recent changes?
I have a T rating on one rear, and an H on the other. The car's original spec is T so I've been told, so presumable the H is no problem per se as it is a higher rating. In fact, it can't be a problem as the two fronts are both H and there's no issue with those.
So does the speed rating have to be the same pairing per axle?
Cheers
Has thanked: 1413 times
Been thanked: 3988 times
So long as the speed rating meets or exceeds the manufacturers spec you are fine. It's not like you are mixing cross-ply and radial tyres on the same axle...
(some people may be too young to understand that sentence,)
Dave54 (Tue Jul 23, 2019 3:56 pm)
Dave54
Has thanked: 1299 times
Been thanked: 1175 times
Post by Dave54 »
As w~o says.
Have a look at the manual here.
https://www.mot-testing.service.gov.uk/ ... index.html
Nothing as far as I can see about mixing tyre speed ratings.
Bob225
Has thanked: 94 times
Been thanked: 857 times
Post by Bob225 »
Pmsl - if there both the same size, Are in good condition and have legal tread no issue - Do you really thing a tester has the time to go around every tire and note down the spec, and to know exactly the 10's of 1000's of combinations multiplied by the 1000's of manufactures and how every one treats there car, i think not
imho someone is trying to up-sale you some tires
I will have a look see at the mot handbook
Edit. As i thought load ratings are only applicable to class 5 and 7 (basically LGV and mini busses over 14 seats) some light reading https://www.mot-testing.service.gov.uk/ ... tion_5.2.3 (section 5.2.3 Tyres)
Has thanked: 773 times
Been thanked: 3298 times
Did I read somewhere about the spare having to be rated the same as what is on in case you have to change a wheel?
Bob225
Post by Bob225 »
Ah found it ..........................
a.A tyre:
i.load capacity or speed rating not in accordance with the minimum requirements
From another part of the type approval book "The speed capability of all tyres fitted shall be not less than the maximum design speed of the vehicle" eg. what the manufacture specifies
Bob225
Post by Bob225 »
dewaltdisney wrote: Tue Jul 23, 2019 4:18 pm Did I read somewhere about the spare having to be rated the same as what is on in case you have to change a wheel?
In the case of spacesavers there rated to 50mph (usually have a big sticker on the rim rule of thumb is 50 mph for 50 miles (or less)
udaman
Post by udaman »
It's as I thought then. Interestingly though, he isn't trying to sell a tyre and recommended getting one from elsewhere as it would be cheaper. So I don't think it is an up-sell. He also said we can swap it for the spare if it is appropriate.
What I should add is that the tyre in question is a winter tyre. But forgetting performance, economy, etc etc. even that shouldn't make a difference RE the MOT should it?
Thanks for all the replies
