12V water pump recommendations for sustained use?
- Has thanked: 12 times
- Been thanked: 5 times
I have this pump, which is pretty good:
https://www.ebay.co.uk/itm/72W-12V-130P ... SwiMBdrX1T
The only problem is, you can't really use these pumps for more than about 30 minutes before they get too hot. I want a 12v pump that will withstand a few hours of continual use when used with mist nozzles.
Any recommendations?
- Has thanked: 2 times
- Been thanked: 76 times
A 12vlt pump, pumping cold water about should not get hot, it use's the water as a coolant and as a lubricant, hence the instructions not to run dry, it should easily manage an irrigation system, however, if you are using a lot of misting nozzles, and I assume they are in a green house then your problem could be that you are overloading the pump, a misting system takes a lot of water pressure to work correctly, you need to find out their flow rate and "Bar" pressure multiply by the amount you have, and compare it with the pumps ratings.
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Sorry, but I have no idea of the purpose or function of mist nozzles.
Can you use a submerged pond pump? They'll work away for years without overheating.
- APDIY
- Has thanked: 382 times
- Been thanked: 37 times
I agree with you and the advertized uses.Nos wrote: ↑Mon Feb 10, 2020 7:21 am A 12vlt pump, pumping cold water about should not get hot, it use's the water as a coolant and as a lubricant, hence the instructions not to run dry, it should easily manage an irrigation system, however, if you are using a lot of misting nozzles, and I assume they are in a green house then your problem could be that you are overloading the pump, a misting system takes a lot of water pressure to work correctly, you need to find out their flow rate and "Bar" pressure multiply by the amount you have, and compare it with the pumps ratings.
- APDIY
Pressure: 0.90MPA (MAX 130PSI)
The largest flow: 6L/MIN
The work: intermittent service (continuous working at different working pressures at different times)
Service life: more than 500-1000 hours of continuous work
- Has thanked: 42 times
- Been thanked: 2473 times
Just FYI, mist nozzles are used for a variety of things, but in short it produces a fine mist. Some use them in green houses as the water is so fine (Mist) it does not damage the plants.
In order to achieve mist, high pressure is required, your average pond pump does not produce enough pressure to properly operate a mist nozzle.
Pressure is much more important than Litres per minute for mist. I get about 100psi from the garden tap, so these pumps are actually better at 130 psi. I don't need much volume of water, it's the pressure that I need. Any other ideas guys?someone-else wrote: ↑Mon Feb 10, 2020 11:35 pm mist nozzles are used for a variety of things, but in short it produces a fine mist. Some use them in green houses as the water is so fine (Mist) it does not damage the plants.
