Another pressure washer
Grumpy people only in here please
Laird
Has thanked: 30 times
Been thanked: 20 times
Post by Laird »
What is it with pressure washers? After having two, a Nilfisk and then a Wolf, in 4 years, and having both give up on me after only casual use. I decided I wasn't going to throw good money after bad and I held back for 2 years on getting another one, but now have decided to try again. This time I've ordered a Qualcast after seeing my neighbor busy with one which he had just bought. I hope this time it will keep working for longer than a couple of years.
I only use the washer for occasionally washing down the car and now and again on the paving round the house.
Hopefully this one will work for more than a couple of years.
Laird
If all else fails, use 6 inch nails
village idiot
diesel demon
Has thanked: 104 times
Been thanked: 104 times
Re: Another pressure washer
Post by village idiot »
If you still have the nilfisk let me know what you need
Sent from my Moto G (5) using Tapatalk
i love being married
it's great to find that one special person that you want to annoy for the rest of your life
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Has thanked: 42 times
Been thanked: 2478 times
I still have a karcher. I would never buy an "own brand" pressure washer.
I don't know how old it is, but after every use I tip it up at the end so the water can run out (It sits on a towel on a concrete floor) I will not use it in winter time, no matter how dirty the car is.
Oh, and yes, I always take all the hoses / pipes off. Been doing this since the first one froze.
kellys_eye
Has thanked: 357 times
Been thanked: 1789 times
Post by kellys_eye »
They're not difficult or too complicated to take apart and repair if you're of a mind.
Like s-e says, keeping it from freezing is critical to survival. Not so sure allowing all water to drain is a good idea though unless you plan to pack it away for a lengthy period. Regular use and following the manufacturers care instructions seem to be enough.
If you paid a lot for the machine you currently have then contact the seller to complain - your statutory rights allow for a 'reasonable expectation for use' from the unit and under 2 years, whilst potentially outside what the manufacturer may say is their warranty period, doesn't necessarily make it 'reasonable'. I'd expect at least 5 years life from one and would whinge like a woman if I didn't get it!
If you don't have a receipt, contact the manufacturers directly an see what they have to say.
Cannyfixit
Has thanked: 102 times
Been thanked: 183 times
Post by Cannyfixit »
I have had my Karcher for ten years,more luck than quality I think however I always run a little anti freeze through the machine before putting it away for the winter
Laird
Post by Laird »
Assembled and took the Qualcast out for its first run. So far so good. Now, will it last longer than a couple of years??
Laird
Bob225
Has thanked: 94 times
Been thanked: 857 times
Post by Bob225 »
Last use of the year I blow out my Karcher K2 with air , I usually give it a clean and pull the filter too
Retired
Has thanked: 1999 times
Been thanked: 586 times
Post by Retired »
Good luck with your Qualcast. :salute:
I've had my Nilfisk 120 bar pressure washer for over four years. I store it in the shed and have never drained it. A few weeks ago I decided to pressure wash our flagged patio and flagged paths so pulled the PW out and coupled it all up; it fired up immediately but with nothing coming out of the lance? The motor ran for a sort time before it cut out.
Not wishing to search for the instructions which came with it I browsed YouTube for information. Because the PW had been stored for a long winter without being used it only needed bleeding. I removed the pressure hose from the power unit and let mains pressure water flow through until all bubbles cleared then I coupled up the pressure hose and again let water discharge at mains pressure; it took about half an hour before the motor would fire up again but now everything was perfect and I completed the job.
You say both your previous PW's have given up on you; could the problem simply be that they required bleeding? :scratch:
Kind regards, Col.
Dave54
Has thanked: 1299 times
Been thanked: 1175 times
Post by Dave54 »
I had a couple of pressure washers that packed up after a season or two despite being drained and kept frost free. I thought I'd get a Karcher.
Saw a Lidl one much cheaper with a 3 year guarantee before I got round to getting a Karcher. That's about 5 years ago.
(Sometimes I feel as if my life comes from Lidl! :lol: )
Laird
Post by Laird »
Bleeding might have been the remedy for the Nilfisk, I don't know, and I didn't think of it at the time, but for the Wolf it was the on/off switch, which didn't work. At the time, I didn't have the umph to start taking the thing apart and anyway having no spare parts to replace the switch, combined with being p****d off that it had given up so soon, I decided to dump it.
So, they both went to the recycling.
I had the Qualcast out again yesterday and all was good. The only pain is coiling the pressure hose after use...not a serious complaint.
Laird
Return to “The Grumpy corner”
