Need advice on cracked stair risers
Posted: Mon Jan 21, 2019 2:25 am
by karlmanderson193
Hello,
I've just ripped the carpet off my stairs for the first time and have discovered mostly all of the stair risers are cracked across the middle. The cracks go all the way through. I haven't been able to find much information about this online, so any help would be appreciated. I have added a pic of one of the stairs for an example, most of them are like this. I don't have any access to underneath the stairs as it's all been plaster boarded up, so removal of these looks difficult.
stairrisers
Firstly does this pose any structural risk? and secondly what is the best way to go about fixing it? Would wood epoxy or filler do the trick?
I was hoping to be able to sand all my stairs back and stain them
Thanks in advance
Re: Need advice on cracked stair risers
Posted: Mon Jan 21, 2019 8:32 am
by ayjay
Thanks in advance
I wouldn't really call it structural, but it's not good. The riser is fixed to the back of the tread and supports it. With no support here, the treads will creak and move, any filler will just crack up.
The only way to fix it, short of replacing the risers, (very invasive) is to put a ply cleat (glued and screwed) on the back of the riser to fully cover the crack.
Posted: Mon Jan 21, 2019 10:56 am
by karlmanderson193
Thanks in advance
Thank's for your reply, unfortunately I have no way of getting behind the risers to do this with it being plastered up, and I live in a local authority house so they are a bit funny with work being carried out, but the chances are they wont fix it and if they do it will be a bodge job, the other repairs they have done for me have been questionable to say the least.
All the stairs are indeed starting to creak and move, with the bottom 3 treads actually snapping away at the corners
As for the risers, filler would crack rather easy with the movement but what about something like Bondloc Wood Epoxy? Would that give it any additional flexibility over filler to work for this? It's the only other way I could see of doing it without access to behind the risers
stairs2
Posted: Mon Jan 21, 2019 12:10 pm
by Job and Knock
In that case the only thing I can suggest is making-up a tightly fitting 6mm plywood facing for the front of that riser. The riser face can then be scraped/sanded back to show clean wood. The plywood can then be glued and pinned onto the face of the riser, ideally using a gap-filling adhesive, something like a cold hide glue (e.g. Elmers or Titebond). The problem is that you'll need to keep off that staircase for at least 12 (preferably 24) hours to ensure that the glue sets thoroughly. It may be possible to use a fast setting glue, such as Everbuild D4 PVA glue, but you still need to keep off that staircase until it has set thoroughly (or at least a couple of hours). The choice of glue for this is very important - ordinary PVA just won't do, PU glue will potentially blow itself off and RF glues and the like require pressure and cramping that will be all but impossible to achieve in this situation
This technique is not 100% guaranteed to work, but without access to the underside I doubt that there's much else I could recommend
Posted: Mon Jan 21, 2019 1:05 pm
by ayjay
Job and Knock wrote:In that case the only thing I can suggest is making-up a tightly fitting 6mm plywood facing for the front of that riser. The riser face can then be scraped/sanded back to show clean wood. The plywood can then be glued and pinned onto the face of the riser, ideally using a gap-filling adhesive, something like a cold hide glue (e.g. Elmers or Titebond). The problem is that you'll need to keep off that staircase for at least 12 (preferably 24) hours to ensure that the glue sets thoroughly. It may be possible to use a fast setting glue, such as Everbuild D4 PVA glue, but you still need to keep off that staircase until it has set thoroughly (or at least a couple of hours). The choice of glue for this is very important - ordinary PVA just won't do, PU glue will potentially blow itself off and RF glues and the like require pressure and cramping that will be all but impossible to achieve in this situation
:withstupid:
