PSB1800 flashes 3 times, help!
- Has thanked: 1 time
Hello,
I have a Bosch PSB 1800 LI-2 since January 2017 bought on amazon. It started to doing something strange, it flashes all the 4 leds (3x battery level plus the lantern led) all at once, three times occasionally after press and hold the trigger, it does this on all the modes and forces and do nothing other than flashing the 3 times, after try pressing the trigger a few times it runs perfectly with the same power as when it was brand new, and only do it again after a few minutes with no use.
Batteries are fully charged, and it is not used everyday, just for bricolage here and there. What can it be? Should I ask amazon for warranty or is there anything I can do to fix it?
Here is a video that I recorded just now showing the issue
- Has thanked: 731 times
- Been thanked: 2304 times
Re: PSB1800 flashes 3 times, help!
is it after a hard heavy period off use
may be overheat protection
what happens if you put the batteries through a charge cycle??
another though
is it stored somewhere cold ??
if so take indoors for an hour and try again
Hmm, stored always indoors, on my dad's garage, on a shelf inside his case... For what it shows it have to be a battery issue right? My dad tought about the trigger contact switch but if it happens almost always at the first pull of the trigger must be something else or otherwise it would do almost in every pull of the trigger right?
if both give the same indication then that would normally mean the tool or charger as the chances off failure off both batteries at the same time is minimal unless storage or use related warnings are indicated by the unusual light combination
- Has thanked: 42 times
- Been thanked: 2478 times
Google is your friend Click here
