Advent vice versa tape measure
Reviews of hand tools in this forum please.
London mike 61
Has thanked: 193 times
Been thanked: 266 times
Post by London mike 61 » Tue Apr 16, 2019 12:09 pm
For a very long time I’ve been irked by the fact that the Stanley fatmax tape measure that I’ve been using has got feet and inches on one side of the tape and metric on the other. When doing measurements from left to right, the metric side is nearest to you and imperial away from you so if the edge you want to measure is on the imperial side then you have to hold the tape awkwardly to get a metric reading.
So, I’ve finally found a tape measure that is everything I want after watching a review of it on another site. The Advent tape has metric measurements on both edges of the tape on the upper edge AND both edges on the underside of the tape as well. Which means that you can take accurate measurements from many different angles without having to twist the tape or your neck.
The tape has a locking button and a button to stop the tape retracting too fast and slicing a finger off in the process.
I bought mine from toolstation and got the 8m tape but they also do a 5m one as well
There are occasions when a imperial tape has its use but for most of what I do the Advent one will be my go-to tape from now on.
Mike
These users thanked the author London mike 61 for the post:
Dave54
Rorschach
Has thanked: 50 times
Been thanked: 843 times
Re: Advent vice versa tape measure
Post by Rorschach » Tue Apr 16, 2019 1:01 pm
Gosforth Handyman did a video about this recently, I am going to get one, they look great.
Dave54
Has thanked: 1106 times
Been thanked: 1011 times
Post by Dave54 » Tue Apr 16, 2019 1:09 pm
I'm going to get one next time I go to toolstation.
Annoying as anything having inches on a tape at all, let alone in the "prime spot"
I changed over to metric over 30 years ago.
Liam2349
Has thanked: 2 times
Been thanked: 19 times
Post by Liam2349 » Tue Apr 16, 2019 1:21 pm
Great idea to print under the tape as well. Anyone know what the stand-out is on these, vs. the near-4m on FatMax Pro tape measures?
I probably won't be getting one but it looks pretty cool, and less than half the price of the FatMax Pro tapes, though my FatMax Pro is mostly metal construction. I also don't use inches, not unless someone else wants something measuring in inches. Looks like the 8m variant has a large tip on the tape, similar to the FatMax ones.
London mike 61
Post by London mike 61 » Tue Apr 16, 2019 1:29 pm
Rorschach wrote:Gosforth Handyman did a video about this recently, I am going to get one, they look great.
Yeah, he did a great review, here is the link
https://youtu.be/9vg776v1VF4
Mike
nsansomuk
Post by nsansomuk » Thu May 07, 2020 3:44 pm
Stanley do an all metric version which is very nice, although expensive.
Also... I imported a Johnson all-Imperial one which is my absolute favourite for timber framing projects.
These users thanked the author nsansomuk for the post:
London mike 61 (Thu May 07, 2020 3:48 pm)
Chippo1
Has thanked: 10 times
Been thanked: 106 times
Post by Chippo1 » Thu May 07, 2020 5:25 pm
Used one for several years now it is very good and accurate. In fact I wore mine out. Recently bought a Magnusson tape from Screwfix very good also dims both side and a magnetic tip, so really good for picking up screws n nails, saved the back.
Bob225
Has thanked: 61 times
Been thanked: 731 times
Post by Bob225 » Thu May 07, 2020 6:55 pm
You want one of them their euro tapes
8m Stanley Fatmat 0-33-892
eg. https://www.ebay.co.uk/itm/STANLEY-FatM ... SwG21ec3aZ
Chippo1
Post by Chippo1 » Thu May 07, 2020 7:26 pm
That Stanley still does not have measurements on the reverse of the tape, which is so much better for marking out as the edge of the tapes sits tight to the work piece.
Return to “Hand tool reviews”
