Heating boiler fault
Locked
chigley
Post by chigley »
i have a vokera mynute 30he i am getting a fault code 52 coming up on display any ideas please.
thescruff
Has thanked: 360 times
Been thanked: 3723 times
Re: Heating boiler fault
Post by thescruff »
Is the red led showing, try a reset.
chigley
Post by chigley »
Have tried reset but just comes back on thanks.
thescruff
Post by thescruff »
Have you check the pressure.
Does it all work still
chigley
Post by chigley »
pressure is ok and still works
chigley
Post by chigley »
the boiler will run for maybe a few hours then go off with fault code 52 you reset and its fine for a while then goes off again.
Agile
Gas/Heating Expert
Has thanked: 24 times
Been thanked: 293 times
Post by Agile »
Unfortunately the boiler instructions dont help by just saying its an "internal" fault!
If I was called to fault find then I would be monitoring the boiler flow temperature at the point that it faults.
Depending on that result of that then I would move on to look at something else.
I think you may need professional help!
Tony
chigley
Post by chigley »
Thanks for all your help.
Locked
