Oh I hope so haven't played with one of them since I was about 13.Razor wrote:sounds more like a mecchano set than a boiler
Intergas 24/18 HRE compact Combi
- thescruff
- Has thanked: 360 times
- Been thanked: 3734 times
Re: Intergas 24/18 HRE compact Combi
- Gas/Heating Expert
- Has thanked: 24 times
- Been thanked: 293 times
Welcome to the 21st Centuary!
The water in the Bath area can be quite hard.
If the secondary tubes get blocked with lime scale the only solution is to treat them in situ with acid ( unless you replace the entire heat exchanger! ). No simple plate to change/clean!
I recommend you fit a good magnetic scale reduce in the the cold water inlet.
Tony
Tony
I hope you are fitting TRVs and all the other modern controls!
Funny time of year to be changing a boiler when its freezing!
Tony
Tony
- thescruff
Whilst I probably will change it now, the plan was to get it in ready for any emergency because it's so damn cold.Agile wrote:I hope you are fitting TRVs and all the other modern controls!
Tony
Plan B, was because the gas has gone up 300% since this time last year.
Plan C was the less I give the vultures in gov.con the happy I am.
The Government are not involved in your choice of new boiler.
Its your wallet which pays the bill and its you who will see all the savings!
Hurry up and get it in while its warm!
Tony
Tony
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
If you're in a hurry get a BG crew round, conventional to combi is about 13 hours labour inc flush
Best of the best
And don't fit an inline scale inhibitor but the hydroflow doobries seem to work (a bit)
Best of the best
- thescruff
I'd love to see BG try and flush a 36 year old system with the original water init
Think it may need a wire brush on a flexible rod.
If I tried hard I could doitall myself in less time that that.
- Razor
They would probably give you a powercleanse - 24 minutes for that
Or full flush up to ten rads - 2 hours 20 minutes
- thescruff
I may borrow my BG mates flue gas gadget for an hour while he's drinking the coffee.Razor wrote:They would probably give you a powercleanse - 24 minutes for that
- Razor
Well he's not an installer then they don't have them
- thescruff
- Razor
And don't forget sticking his probe up some old dears flue!
Whatever happened to Dickie
- Mehran2
- Has thanked: 6 times
- Been thanked: 39 times
well that is interesting John as I would direct you to section 9.1.4 on page 28 of the manufacturers instructions for a intergas HRE boiler.
which i would quote for you:
now it does tell you what the reading should be if you so wish to check I would check anyway just in case9.1.4 Combustion
The combustion for this appliance has been checked, adjusted and preset at the
factory for operation on the gas type defined on the appliance data plate. No
measurement of the combustion is necessary. Do not adjust the air/gas ratio valve.
- thescruff
- thescruff
I ain't got it yet Mehran to read 9-1-4 combustion, but you can be sure I will at some time.Mehran2 wrote:well that is interesting John as I would direct you to section 9.1.4 on page 28 of the manufacturers instructions for a intergas HRE boiler.
I think they shut down for Christmas.
