DIY Forum
DIY Forum/Home improvement advice
A-Z CONTENTS | DISCLAIMER | DIRECTORY | DIY VIDEO | HOME | SAFETY FIRST | FORUM RULES
It is currently Thu Jul 24, 2014 5:22 am
Time zone: Europe/London [ DST ]
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: Sun Feb 12, 2012 2:50 pm
Offline
Has thanked: 1 times
Been thanked: 0 times
I am looking for a bit of advice.
I want to put some chrome faceplates (light switches and power) and chrome light fittings around my flat to make it look a bit nicer. The problem I have is when I look at the wiring of the current sockets and light fittings there aren't any earth wires. I've been told that this is because metal conduit in which the wiring runs through is used as the earth. I have 2 questions:
1. Can I run an earth wire from the chrome switch/socket to the back box (behind the switch/socket) that I can see is connected to the metal conduit?
2. There is no back box behind the light fittings so can I clamp an earth wire round the metal conduit and run the wire to the chrome fitting?
Thanks in advance.
Top
 Profile
You may not be able to see the full post including pictures unless you register or log in
PostPosted: Sun Feb 12, 2012 3:14 pm
Offline
Has thanked: 11 times
Been thanked: 77 times
1. yes no problem
2. yes but im supprised there is no box either, please verify the conduit is effectivly earthed.
Top
 Profile
PostPosted: Mon Feb 13, 2012 12:46 pm
Offline
Thanks for the advice.
I will need to check there isn't a backbox at the end of each light fitting as the one I did check all I could see was the metal conduit with the 2 wires coming out of it and through the ceiling.
With regards connection of the earth wire to the backbox is there a special clamp I should use or will a screw and cable clamp through it be okay?
Top
 Profile
PostPosted: Wed Feb 15, 2012 4:25 pm
Offline
Has thanked: 36 times
Been thanked: 273 times
Conduit was in the past used both to protect the wires and to connect to earth but not all was connected to earth some only gave mechanical protection.
We would normally use an earth loop impedance meter to verify if the earth existed. There is a problem with DIY as these meters are not cheap.
Some of the more expensive socket testers like this one Image do have a basic earth loop test but still cost £44.16 + VAT so are not cheap and you would still need to make some form of adaptor to use them with lights.
So I would think it will likely be cheaper and safer to get an electrician to do this work for you. I think the biggest challenge for any DIY guy is to work out when it's just not worth doing the work as DIY and biting the bullet and paying out for a professional. I would think here because of the cost of test gear it is a job you should back heal.
Top
 Profile
PostPosted: Thu Feb 16, 2012 2:49 am
Offline
Using unearthed metalic cable containment is only applicable with double insulated conductors, any conduit or trunking containing single insulated cables has to be earthed and compliant for use to clear faults of the largest circuit install within.
Top
 Profile
PostPosted: Thu Feb 16, 2012 9:24 am
Offline
Troll Headbutter
Has thanked: 227 times
Been thanked: 504 times
When I first purchased my current house, it was all done in VIR and conduit to provide earths. It was a bit hit and miss to be fair - I knocked myself a long wander lead up that I could connect to the MET and at least carried out a simple resistance check at the points of concern.
It worked, but was all ripped out anyway.........a large portion of it had been on fire at some point. :lol:
BG
_________________
Ray ate all the pies!
Top
 Profile
PostPosted: Thu Feb 16, 2012 12:19 pm
Offline
Has thanked: 7 times
Been thanked: 143 times
Years ago when I assisted in wiring the infamous 'Tricorn Nightclub' in Portsmouth we ran everything in screwed conduit then put a grub screw through every join to make good earth continuity.
PITA! :roll:
John
_________________
Top
 Profile
Display posts from previous:  Sort by
Similar topics
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
News News Site map Site map SitemapIndex SitemapIndex RSS Feed RSS Feed Channel list Channel list
ultimatehandyman privacy policy
Contact
phpBB SEO
