I have been looking at a bungalow which has been 'done' up as a result I have a couple of questions re the electrical bits and pieces.
1 Can you have a open electrical socket under a sink?
2 Where the dishwasher should go (next to the sink) there is two thick grey wires to the socket hanging loosley.
3 The fuse board and distrubtion box for the tv are scewed onto chipboard in the attached garage.
Any advice would be appreciated
Many thanks
Pam
Part P and help please
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
Re: Part P and help please
As far as I'm aware, yes. As long as it's not got water running down around it, it shouldn't be an issue.pammyb wrote: 1 Can you have a open electrical socket under a sink?
They'd be better clipped to the wall but again they are surface and protected (as such, by the sink unit and the dishwasher) again not really an issue. You could always lay surface trunking in and feed the cable if you are concerned.pammyb wrote:2 Where the dishwasher should go (next to the sink) there is two thick grey wires to the socket hanging loosley.
Is this just for the TV or is it the supply for the house? Chipboards fine, would be better if it was boxed in but just to be tidy.pammyb wrote:3 The fuse board and distrubtion box for the tv are scewed onto chipboard in the attached garage.
Jaeger.
hi and many thanks to everyone
the 'fuse' box is for the whole bunaglow and is in the attached garage screwed onto some board. What about fire risks?
I just think it is strange to have an open socket underneath the sink I think it would be for the dishwasher to be plugged in.
Am I being too cautious and woundering if they have done up this bunaglow on the 'cheap' taking shortcuts,
Is their anything else I need to look for?
Many thanks
Pam
xx
Many thanks
Pam
xx
- Jaeger_S2k
- Pro Handyman
