Main Fuse box
- Contact:
Main Fuse box
A bit of a daft question really, but can you please advise me when i turn th electricity off at the mains is the wiring that feeds into the fuses are dead and can be safely touched, the reason i ask is that i have noticed a wire thats possibly dangerously loose and need to re insert it ???
- BANNED
- Been thanked: 1 time
well it depends which wire. If it is the meter tails into the board then these are turned off by an external double pole isolator (if you have one fitted) if it is a wire on the fused/circuit breaker side turn the main switch off on the board and it should turn it off. You can buy electrical testing screwdrivers from B&Q to determine safely is something is still live
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
Can you post a picture of what wire you are saying is loose and needs re-inserting? then we can advise you better, if it is a circuit feeding from the fuseboard, then it will be isolated by turning the fuse box off, but as said before if its the meter tails, large round cables either red and black or grey , then they are NOT isolated by the fuseboards main switch and you should seek the advice of a qualified electrician .
Nick
Nick
- Electrician
- Contact:
