Digital TV
Digital TV
Hi All, Hope someone can help!!?!!
I have SKY+ in the living room and now want to move it 2 meters to the otherside of a wall into another room. Th problem is the cable is not long enough, so i have tried to extend with some digital cable and digital conectors. When i do this i cant get a signal(obviously i have done something wrong) SKY+ use 2 cables into the back and i have tried to extend both with normal digital cable and conectors.
I have moved a normal sky box the other way conecting the same way and this works fine.(this has only 1 digital cable in the back).
Can someone tell the correct way to sort this problem plaese?
I hope this makes sense.
Cheers
Cheers
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
Are you sure you have used the correct joiners?? The ones you need are the ones with a screw on connector on them , and the centre core is left poking through the middle. You need to make sure that the joiners are making a proper contact and that you have not got the 2 cables crossed as i think this stops it from working. Normal co ax cable is just not up to the job as are coax plugs and couplers . you have to use a CT100 or equivalent cable and the proper f type connectors to make sure the jobs done properly
Nick
Nick
Hi Sparkydude, Thanks for the reply. I think i have the correct joiners, because as i say i have moved a normal sky box the other way and connected an extension.
I brought the cable from Focus, maybe thats the problem i'm going to look for some CT100 cable like you say.
Help!! I thought this would be quite straight forward. Huh should have known better.
Any more ideas would be great.
- BANNED
- Been thanked: 2 times
- sparkydude
Great glad to hear it. What was the problem in the end then just so we know for future reference incase anyone else wants to do the same.
Nick
Nick
- BANNED
- Been thanked: 1 time
It was a silly thing, I went to maplins and was advised of the connectors i needed. But as it turned out they were the wrong sort even though maplins said they were correct. So i bought some more from B&Q and they did the trick.
Type F Connectors are the correct sort for anyone who needs to know.
They looked exactly the same as the maplins ones apart from the inside.
So, as you quite rightly sugessted Sparky Dude it was the connectors. .
And when i went to the sky forum alot of people were saying the same thing as you, this made me look into it further.
So thanks and thanks to ban-all-sheds, and Tim'll fix it thanks also, it has redueced my signal slightly on the reading but not alot, because it is only a 2 meter extension.
So thanks all for your input.
- BANNED
