I know that the government has introduced part p to allegedly make home electrics safer, but in my opinion it is just a way of taxing people.
Why do we use 220-240V for our electricity supply?
Is there not a safer voltage that could be used, like the 110v that the Americans use?
Could a lower voltage not be used?
What is considered a safe voltage?
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
Well in theory yes we could run on a lower voltage, However the trouble is the lower the voltage then the higher the current, so that means that the cables would have to be a lot bigger for the same job, This would not only mean the hopusehold wiring, but flexible cords on appliances.And extra costs in transformers and distribution equipment.
Nick
Nick
- Deceased 21-10-2011 R.I.P
- Has thanked: 8 times
- Been thanked: 90 times
The Yank distribution cos don't use thicker cables. They use more transformers so the distances of LV distribution are much lower. That means most of their distribution is at MV, unlike ours which is at LV.
But you still need thicker cables in the house. And the voltage above earth is twice our SELV 110V because each of the two wires of our SELV is at 55V to earth, whereas the yank has to be 110 V to earth so they can get three phase.
