Making a cutout in Perspex
All Questions about Acrylic in here please.
Locked
mgartner
Post by mgartner »
Here is my project. I need to cut out a square shape, for a cat flap, in a sheet of 2mm perspex. What are the best tools and methods for this kind of cut? Jigsaw with metal cutting blade, electric drill for pilot holes, etc..??
Thanks,
M. Gartner
Has thanked: 999 times
Been thanked: 915 times
Re: Making a cutout in Perspex
Post by ultimatehandyman »
Yes, carefully drill a pilot hole using a metal drill, then cut out the hole using a jigsaw and metal cutting blade.
Bruv
Has thanked: 5 times
Been thanked: 5 times
Post by Bruv »
Be a hell of a lot easier to up the thickness of the perspex, 2mm will flap about a lot.
mgartner
Post by mgartner »
ok, great thanks. I need the whole piece to be fairly lightweight--what do you think would be a better thickness to avoid flimsiness without getting too thick?
amarg
Has thanked: 12 times
Been thanked: 32 times
Post by amarg »
2 or 3mm should be fine, in such a small piece although you could probably get away with 5 or 6 mm thick
Locked
Return to “Acrylic Forum”
