hi, I'm wanting to bend sheet acrylic (3mm thick) at home for making jewellery, is there any inexpensive way of heating it up without using a line bender? or any fancy machinery?
any comments or help would be greatly appreciated!
thanks, Rosie
bending acrylic/plastic at home
We replaced a 10mm thick piece of acrylic that was cut and then shaped to replace a broken one for a pillar drill guard. We bent a steel plate 90 degrees then clamped one end of the acrylic to the steel. We then placed the steel / acrylic into the oven at as low a temperature as we could until the acrylic was able to soften and form around the steel plate - once its soft like that, you can assist it with your hands (using suitable gloves). Can't remember the temperature, but i'd be inclined to start around 140 degrees and work up from there. It's a bit of trial and error.
The oven we used was an industrial oven, but thats not really of any relevance.
- ultimatehandyman
- Site Admin
- Has thanked: 999 times
- Been thanked: 915 times
Sorry Rosie,
I missed this post and only noticed it when bredred replied
You can try a heat gun-
http://www.youtube.com/watch?v=iUTNcQlHiho
