I need to make a *U* shaped contraption with some 12mm stainless steel rod (unthreaded) and a pair of BSP threaded elbows (I don't need threaded elbows but it's all I've found on eBay so far).
I plan to Epoxy the rod into the elbows but am unsure what size I need.
I can get 1/8" - 1/4" - 3/8 - 1/2" - 3/4" - 1" BSP (and so on up to 2.5", but doubt I'll need anything that large).
What size is closest to 12mm to give a snug fit and leave room for some epoxy?
BSP bore sizes
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
- Has thanked: 1299 times
- Been thanked: 1175 times
BSP bore sizes
There's a table here
https://en.wikipedia.org/wiki/British_Standard_Pipe
That's external threads I assume, so you want the minor diameter, which will be roughly the inside diameter of a internal thread.
So I make it 1/4 or 3/8 BSP depending on how slack you want it. Might have to run a drill into the 1/4"
- Has thanked: 94 times
- Been thanked: 857 times
BSP bore sizes
stainless steel round bar or SS tube
do the elbows have to be threaded for something to screw into them ?
edit. what about a pneumatic elbow ? they are typically metric
https://www.ebay.co.uk/itm/METAL-PNEUMA ... Swdd9ae3b1
https://www.ebay.co.uk/itm/RM0312E-EQUA ... SwJ~9bJo2y
- ayjay
BSP bore sizes
The 14 mm of the 3/8" BSP is a bit slacker than I'd like - I may have to buy another pack of Epoxy!
I'll have to see if I can find some 5/16" BSP elbows.
No need for threads on any of it Bob, the threaded elbows I mentioned were the first I found.
I'll do some more searching later
