Hi guys,
Anyone recognise this try or of bolt/screw head?
The ‘key’ I have has broken, and I can’t source a replacement!
Cheers
Odd bolt type
- Been thanked: 4 times
- Has thanked: 609 times
- Been thanked: 2276 times
Odd bolt type
I think it is a Key Rex Tam 6 lobe security screw. I am not sure if the bits come in the security bit sets you can buy for £7/8 here is a link to a USA manufacturing company you could enquire with if you get stuck https://www.brycefastener.com/tam-6lobe ... crews.html
- Dave54
- Has thanked: 1234 times
- Been thanked: 1110 times
Odd bolt type
Or is it a Torx Plus Security?
Shows the Torx Plus here.
https://en.wikipedia.org/wiki/List_of_s ... #Torx_ttap
Bits are available apparently.
If possible, and if the "security" aspect isn't needed, I'd change that screw for a stainless socket head cap screw "allen pin" or similar.
Odd bolt type
Hi All,
Thanks so much for commenting.
I’ve looked at torx bits, but the torx bits I find only have 6 sides, whereas these screws have 7!
I’ve tried replacing, but the bolts seem to be an odd size, between M7&M8!
I’m guessing these must be custom completely!!
- Has thanked: 673 times
- Been thanked: 2046 times
