Tiling Bathroom Floor
kevinsmbuk
Has thanked: 211 times
Been thanked: 27 times
Post by kevinsmbuk » Wed Oct 23, 2019 4:21 pm
Hi I want to tile my bathroom floor. At the moment there is just vinyl covering floorboards with ply that was not fitted correctly that will be coming up to lower the overall height.
So the plan was remove ply to floorboard level, use thinset to install hardiebacker boards and screw down, tape joins and then tile over the top.
The bit I wanted to check was it ok to install 6mm backer boards directly to floorboards, or is there a need to screw down ply first?
wickedwjc
Has thanked: 30 times
Been thanked: 12 times
Post by wickedwjc » Mon Nov 04, 2019 11:12 am
I don't see any issues with fixing the hardiebacker directly to the floorboards.
These users thanked the author wickedwjc for the post:
kevinsmbuk (Tue Nov 26, 2019 10:45 am)
kevinsmbuk
Post by kevinsmbuk » Tue Nov 26, 2019 10:45 am
Many thanks, I thought this might be the case!
