1st time decking post layout
Calzor Suzay
Has thanked: 1 time
Post by Calzor Suzay »
I'm going to building a decking for the 1st time.
Going to be using C24 47mm x 100mm joists attached to 100mm x 100mm posts via m12 coach bolts.
Will be using 400mm centre gaps between joists, 34mm x 145mm boards on the joists.
It'll sit no more than 100-200mm off the ground.
I plan to run the posts about 1200mm apart as it fits in with the size etc but not I'm not sure if you run the posts:-
a) 1200mm apart down every 400mm centres so every joist is attached to a post
b) 1200mm in each direction so across every 3rd joist.
For a deck 2.4m square (not what I have just an example)
Option a) would be 21 posts
Option b) would be 9 posts
Option a just sounds like over kill but I do like to over engineer things :lol:
ayjay
Has thanked: 444 times
Been thanked: 1563 times
Post by ayjay »
A 47 X 100 joist will safely span 1.92m - so they will all need supporting at each end and at every 1.92 m (or less) in between, and don't forget a row of solid noggins at every 2.4m of the joist length.
These users thanked the author ayjay for the post:
Calzor Suzay (Wed Jul 08, 2020 11:46 am)
Return to “General DIY forum”
