It is currently Thu Apr 25, 2019 7:01 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Very confused!
PostPosted: Thu Jan 03, 2013 12:54 pm
Has thanked: 422 times
Been thanked: 3905 times
Jasonpikephoto wrote:
Oh right ok, we'll I have set it on a timer now, so it's on 2 hours at a time. But why is the cylinder still heating up? Even when it's off
Quote:
Because you have a fault, maybe component, maybe an installation error, maybe user error and programming.
PostPosted: Thu Jan 03, 2013 3:12 pm
Has thanked: 1 times
Lol for heavens sake! I'm switching the entire cylinder off via consumer unit
PostPosted: Thu Jan 03, 2013 3:40 pm
I thought we were trying to find the problem, if that is not the case use it as normal and don't worry about it.
PostPosted: Thu Jan 03, 2013 5:24 pm
It's just very confusing that's all. I don't know if there is a problem or if its just me being stupid.
If I have the hot water cylinder switched on, and the Myson Programmer on a timer for the hot water - surely it wouldn't make noises if the hot water is set to 'off'. I just have a feeling it's going to waste energy and cause a higher energy bill.
It makes a noise every 30 mins or so, like a 'shhh' noise. I presume that's it keeping the water to set temperature. But surely it wouldn't do that if its 'off'?
There is a silver box above that red box on the photo attached, with a auto and manual switch on it, what it that?
PostPosted: Thu Jan 03, 2013 5:31 pm
You were going to look at the catalogue and see whether and what type of motorized valves you had.
A zo0med out pic showing the pump and pipes may answer the question.
PostPosted: Thu Jan 03, 2013 5:41 pm
Here's a zoomed out photo of the airing cupboard
PostPosted: Thu Jan 03, 2013 5:50 pm
Thats the boy, is there a make and model on the silver case.
At the begining you said the led is always on for the hot water, in the last pic it's off.
PostPosted: Thu Jan 03, 2013 5:56 pm
I have a photo
PostPosted: Thu Jan 03, 2013 5:59 pm
That's because I turned the hot water off, but there are still noises coming from the cylinder
PostPosted: Thu Jan 03, 2013 6:10 pm
What sort of noises.
When the htg and DHW is off, does the pump stop after several minutes.
Has the immersion heater been left on.
PostPosted: Thu Jan 03, 2013 6:15 pm
Like a loud 'shhhhh' noise, even when the hot water button is off, and even if I switch the entire cylinder off. How do I check if the immersion heater has been left on?
PostPosted: Thu Jan 03, 2013 6:21 pm
Have you got a trip in the consumer unit that just does the immersion heater.
Is there a wall switch in the cupboard, maybe with a led.
PostPosted: Thu Jan 03, 2013 6:23 pm
There is a switch in the consumer unit that says 'water heater'. And there is also is a switch with a led in the airing cupboard
PostPosted: Thu Jan 03, 2013 6:26 pm
Ok start with the switch in the cupboard, is it off, perhaps a pic.
Failing that, next time you hear the noise, turn the trip in the consumer off and see whether it stops.
You could just trip the water heater switch in the CU, and see if it solves the problem.
PostPosted: Thu Jan 03, 2013 8:15 pm
Been testing it all for a while now. The switch in the cupboard was on, but I have now turned it off, along with the switch in the consumer unit. No more noises. So if I switch it in via the Myson programmer, will it turn on? On the selected times?
