It is currently Fri Apr 26, 2019 5:20 pm
PostPosted: Thu Mar 21, 2019 11:36 pm
Has thanked: 13 times
Been thanked: 1 times
I'm planning a garden office DIY build, which will be restricted to 2.5m due to permitted development.
In order to fit some large patio doors I've been given, I was thinking about using joist hangers directly attached to the doors' header. This gives me the size opening I need without breaching 2.5m - which putting the joists on top of the header would not.
The only problem I can see with this is with regards to ventilation. My understanding is that with a cold roof, I need a 50mm ventilation gap, and I assume I'd need to fit a vent along the length of the soffit at either end for airflow - but with my proposed design, I'd only be able to have that at one end.
Hopefully you can see what I mean in the below pic:
Can anyone think of any solutions to this? I'm presuming a vent at one end only wouldn't be sufficient as the air wouldn't actually flow?
The only thing I've thought of it to run the joists from side to side rather than back to front, but I've not seen that done on a monopitched roof like this, and I don't know if there's a reason why…
Pete
PostPosted: Thu Mar 21, 2019 11:46 pm
Has thanked: 709 times
Been thanked: 2041 times
are you aware the 2.5 is from the natural ground level[adjacent to] the structure covers not the base
PostPosted: Thu Mar 21, 2019 11:54 pm
Yup.
PostPosted: Fri Mar 22, 2019 12:22 am
the reason you go front to back rather than side to side is because you buy firings giving the length and degree off angle [or height differential ]you need and they are cut in pairs to go end on end off every joist where joist spacings make minimum difference
where as side to side every single joist needs an exact height spacing and at an angle to accommodate the roof sheet exactly at the same angle
For this message the author big-all has received gratitude : PeteWilliams
