It is currently Sat Jan 19, 2019 8:51 pm
PostPosted: Fri Jan 19, 2018 3:12 pm
Van recently bought, it smokes blue/grey after I start it is more blue, when warmer it smoke less but still does and the smoke is more grey, after pressing acceretion pedal it smokes a bit more for short time and then slow dawn, there is no power loss, also I've checked turbo, can't feel any movement on turbo shaft, altough there is some oil in outlet pipe ( this one going to intercooler ) also replaced oil separator ( old had holes in pipes ) any idea what else can check before I go to mechanic and spend a lot of money?
PostPosted: Fri Jan 19, 2018 3:52 pm
Has thanked: 60 times
Been thanked: 625 times
Best thing you can do is change the oil, filter and air filter
what year and mileage ? is the tax £30 or £90 a year ?
PostPosted: Fri Jan 19, 2018 3:57 pm
Changing oil and filters was first thing I've done, it's 2006 102000 miles
PostPosted: Fri Jan 19, 2018 4:03 pm
Has thanked: 1187 times
Been thanked: 1080 times
Blue smoke usually means oil.
You put the recommended oil in it?
PostPosted: Fri Jan 19, 2018 4:15 pm
any idea when the fuel filter was changed ? a small amount of oil in the intake is normal - but not dripping wet
How much is road tax ? (this tells me what engine tune it has)
PostPosted: Sun Jan 21, 2018 10:23 am
Has thanked: 36 times
Been thanked: 109 times
Carefully remove the oil filler cap with the engine idling. If there's air chuffing out then you could have either blocked breather issues or knackered piston rings.
You could remove the intercooler and tip it up and flush it out with brake/carb clean as it might have collected a rake of oil from turbo oil seal leakage.
