It is currently Mon May 20, 2019 3:52 pm
 Post subject: Varnish over paint
PostPosted: Sun Jun 03, 2018 3:06 am
Has thanked: 4 times
Hi All.
I am in the process of painting the front and back doors. They are wooden with a metal capping on both sides.
I have removed the old paint and sanded them, filled in the low spots and dents with Bonda car body filler, primed the entire door as there were so many bare metal spots it was easier to do it all, and I have given it one coat of Dulux Weathershield. Trade Undercoat. I will be glossing it with the same Dulux, black gloss but I wonder if it is possible to then varnish the door to stop it chipping and give a higher shine? I'd like it as shiny as possible or is there a better way to get a higher shine?
Thanks So much
 Post subject: Re: Varnish over paint
PostPosted: Sun Jun 03, 2018 1:17 pm
Has thanked: 794 times
Been thanked: 895 times
I can't say about varnish as it will not give a higher level of sheen than what could be possible, as far as chipping goes be more careful. For a high gloss finish see the following thread and follow my link to Dynamod's black door. japlac-enamel-gloss-for-exterior-doors-t90647.html
For this message the author OchAye has received gratitude : lijongtao
PostPosted: Sun Jun 03, 2018 6:52 pm
Has thanked: 1560 times
Been thanked: 3911 times
Polyvine do a range of varnishes for over paint. never used them myself though.
For this message the author wine~o has received gratitude : lijongtao
PostPosted: Mon Jun 04, 2018 2:01 am
Thanks to you.
As I am doing the front door I am priming over the Bonda areas, then 2 coats of undercoat and then 2 of gloss. Now, what grade of sandpaper would you use on the undercoat between coats and the gloss between coats?
Also, I find the Bonda difficult to use, I'm sure there's an art to it but I find it hard to work. Can anyone suggest another good filler that is suitable for the exterior that isn't a 2-part one?
Thank you again
PostPosted: Mon Jun 04, 2018 6:58 pm
:dunno: I only ever use 2 pack filler externally. Wet and dry paper (fine) to de-nib between coats.
PostPosted: Tue Jun 05, 2018 3:25 am
Will 1000 grit suffice? Thank you
PostPosted: Tue Jun 05, 2018 7:01 pm
Aye , more than likely.
