It is currently Fri May 25, 2012 10:16 pm
PostPosted: Sun Jan 15, 2012 7:45 pm
Has thanked: 5 times
I've just moved in to an old house and there is a valve for a diswasher under the sink. However, I was plumbing in our DW today and I think the valve has been fitted to the rising main pipe and not the cold water supply pipe. The valve is in a great place for the dishwasher and isn't leaking, but as it is before the stop cock, I assume that I need to get a new stop cock fitted on the existing rising main pipe before the valve? Or can I just replace the rising main pipe?
PostPosted: Sun Jan 15, 2012 8:24 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
Assuming you have a working outside stopcock, I wouldn't worry about it.
For this message the author thescruff has received gratitude : Future
PostPosted: Sun Jan 15, 2012 8:53 pm
Has thanked: 6 times
Been thanked: 85 times
:withstupid:
For this message the author Inky Pete has received gratitude : Future
PostPosted: Sun Jan 15, 2012 9:46 pm
Thanks guys, you've calmed me down a bit. I do have a working outdoor stop cock - I turned it off as soon as I discovered the problem!
Is the valve OK to use, do you think? I would imagine that the water pressure in the rising main pipe is a lot higher than it would be in a cold water supply pipe. I was thinking of putting in a new stopcock in the place where the current valve is, for two reasons: firstly it would take out the valve (self-cutting) which is a weakness, I think; and secondly because it would put the internal stopcock in a better place than it currently is (currently behind a cupboard). Is fitting a new stopcock a straightforward job? I've fitted compression valves in normal hot water and cold water pipes; is fitting a stop cock similar, or does it need something a bit stronger?
PostPosted: Sun Jan 15, 2012 9:59 pm
OAP
mains pressure will be the same.
For piece of mind fit a new stopcock by all mean, use a jointing compound on the olive.
Before you start check the pipe size is standard metric.
PostPosted: Sun Jan 15, 2012 11:26 pm
Has thanked: 4 times
Been thanked: 39 times
Agree with all of the above. :huray:
Your problem is now our problem
PostPosted: Mon Jan 16, 2012 12:47 am
Thanks again - I'd not even considered that the pipe might not be metric. I checked it with a tape measure to see if it was 15mm or 22mm and it was 15mm, but I was just using a tape measure to check; I suppose it could well be 1/2inch. This is a bit of a noddy question, but is there a definitive way to check? Are there marks etc on the pipe that I can look out for? The previous owner doesn't know how long the pipes have been there but he was only there 2 years. So I guess I'll have to measure the outside diameter. This looked like 15mm to me earlier, but then I was only checking to see if it was 15mm or 22mm. I suppose it could easily have been the outside diameter of a 1/2 inch internal diameter pipe (which must be pretty much 15mm). If there are no markings to look for, what is the best way to distinguish 15mm from 1/2 inch? Calipers?
PostPosted: Mon Jan 16, 2012 1:20 am
OAP
Is it the same pipe that goes back to the stopcock.
A clear pic and some info may help us.
Users browsing this forum: No registered users and 7 guests
