It is currently Fri May 25, 2012 10:15 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
PostPosted: Mon Jan 02, 2012 10:53 am
Has thanked: 4 times
New member here. Having trouble with Vaillant Turbomax Plus boiler. No heating but I do have hot water occasionally. I had a leak from a drain valve which I thought was the problem. I've fixed that and still have the problem. I checked pressure which was on 1.0 - amended it and it's now 3.0! Which I think is too high. How do I reduce pressure but mainly what might be wrong with heating? Cheers.
PostPosted: Mon Jan 02, 2012 11:02 am
UHM Super Moderator
Has thanked: 24 times
Been thanked: 63 times
Hi Kaygee :welcomeuhm:
I will move this question to the heating forum for you :wink:
Mod 6
For this message the author moderator6 has received gratitude : 61kaygee
PostPosted: Mon Jan 02, 2012 11:26 am
Has thanked: 51 times
Been thanked: 230 times
Drain some water from the drain valve, back down to 1.2 bar.
The heating problem will most likely need a RGI in to set the boiler up.
Dave
www.drlgas.co.uk
For this message the author gas4you has received gratitude : 61kaygee
PostPosted: Mon Jan 02, 2012 11:58 am
Been thanked: 39 times
Either drain from drain off or you can discharge from a bleed valve on a rad. Between 1 - 1.5bar is sufficient.
Whether you have always had this problem or is just occured, best to get the boiler/wiring checked by registered heating engineer. :-)
For this message the author moggridgeplumbing has received gratitude : 61kaygee
PostPosted: Mon Jan 02, 2012 12:03 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
How did the pressure get to 3bar.
Did it start at 1bar and shoot up when you turned the heating on.
PostPosted: Mon Jan 02, 2012 12:35 pm
I adjusted the pressure by using the key which is awkward and by the time I turned it off the pressure read 3bar
PostPosted: Mon Jan 02, 2012 12:40 pm
OAP
Just lower the pressure as above in that case, either bleed all the rads a few times or drain from a draincock with a hose or small vessel.
Do not use the PRV in the boiler
For this message the author thescruff has received gratitude : 61kaygee
PostPosted: Mon Jan 02, 2012 12:55 pm
Thanks thescruff and the others. That's the pressure sorted! It's back down to 1.5bar. It hasn't kickstarted the heating though so the two weren't linked. And now the water gone cold :dunno:
PostPosted: Mon Jan 02, 2012 1:05 pm
OAP
Is the hot water working now.
PostPosted: Mon Jan 02, 2012 1:16 pm
The hot water is working now but still no heating!
Thanks but I have to go out now - no doubt I'll be back and you may here from me again! Apologies if not posting correctly - new user struggling with format...how to reply etc :lol: :lol:
PostPosted: Fri Jan 06, 2012 10:19 am
Hi! :welcomeuhm:
I'd suggest you call an engineer out to help you sort it out. Especially with the weather we've been having recently, no heat is the last thing I think I could cope with! Good luck! :wink:
Users browsing this forum: No registered users and 6 guests
