It is currently Sat Jul 21, 2018 7:05 am
PostPosted: Sun Oct 08, 2017 9:33 pm
Has thanked: 1 times
Hi
Just wondering of anyone can help me with how to top up the pressure on my boiler.
I have a Vaillant Ecotec Plus 637 boiler and a Santon Premier Plus unvented hot water system and tonight the code F22 has appeared on the boiler and the pressure is low, 0.3bar.
There are no tap heads underneath the boiler. Can I top up the pressure using pliers, or is there a reason that they are not provided with this particular set up?
I've attached a picture of the pipes under the boiler.
Susan
PostPosted: Sun Oct 08, 2017 9:35 pm
Has thanked: 44 times
Been thanked: 1297 times
susanck wrote:
..........I've attached a picture of the pipes under the boiler.
No picture showing. I will guess its too big. For info on how to re size / add pictures, see note in my signature.
For this message the author someone-else has received gratitude : susanck
PostPosted: Sun Oct 08, 2017 10:55 pm
Has thanked: 397 times
Been thanked: 1406 times
See if this helps.
Not sure it's the exact same boiler in the pics, but it may give you some pointers.
Topping up the water is not difficult, it's just a question of opening the right valve/valves and keeping an eye on the pressure gauge.
http://www.vaillantservice.co.uk/Vailla ... _Help.html
https://www.google.co.uk/imgres?imgurl= ... Q..i&w=445
PostPosted: Mon Oct 09, 2017 8:01 am
Has thanked: 811 times
Been thanked: 886 times
The silver braided hose is your filling loop.
From the angle of your pic it looks as though it will need a flat bladed screwdriver to open one of the valves to let the water in, probably the one higher up under the boiler, or maybe the plastic knob has fell off.
Dave
www.drlgas.co.uk
PostPosted: Mon Oct 09, 2017 8:23 am
The silver braided loop is connected to the CH return valve so do I just need to open that? The end is a square so I'd be able to turn that with pliers I think.
My main worry was whether I can top up as normal with the unvented heating or does that make no difference to how the boiler works?
PostPosted: Mon Oct 09, 2017 3:58 pm
Topping the boiler up has nothing to do with the unvented hot water cylinder.
Another pic of the top valve showing the 'square' bit would be helpful
Dave
www.drlgas.co.uk
