It is currently Sun Apr 21, 2019 5:24 pm
 Post subject: using a patress
PostPosted: Sun Mar 12, 2006 7:34 pm
Has thanked: 1407 times
Been thanked: 1250 times
What is the best way to cut/ drill a patress?
I have had varied sucess with doing this and on some occassions I have cracked the bloomin thing, is there an easier way to cut or drill them?
 Post subject:
PostPosted: Sun Mar 12, 2006 8:04 pm
Been thanked: 1 times
i'd love to know, I have tried stanley knives, knocking the bits out, snips, pliers, hacksaw. But I always end up smashing the damn things, my tip is if you need one buy two
 Post subject:
PostPosted: Sun Mar 12, 2006 8:31 pm
Electrician
There are 2 types. PVC and plastic. Plastic ones are normally used with trunking and PVC ones are for surface mounted pvc conduit which normally have knockout holes on them.
I assume UHM that you've been trying to drill plastic patresses? Best way is to use a hacksaw to cut straight down on each side of the area you want to remove. Then use a pair of snips or pliers to do so.
PVC patresses you can drill out with no problems
Hope this helps!
 Post subject:
PostPosted: Sun Mar 12, 2006 8:39 pm
I have not used one for years to be honest but on occassions I have cut down two sides with a hacksaw and then used pliers to remove the piece in between, but every now and again the damn thing breaks a huge hole in the patress.
Luckily the trunking has always covered the hole, but just wondered what the experts did.
I only ever tried drilling one once and it made a right mess :oops:
Thanks Markysparky :thumbup:
 Post subject:
PostPosted: Sun Mar 12, 2006 9:07 pm
Electrician
Just like to add.... when cutting down each side of the area you want to remove. Make sure you cut down at least an inch down the back of the box (the part that goes against the wall) It makes it easier to get the cables in.
You can get pvc boxes with special inserts on them for trunking with a triangular insert which goes into the box at the end. Very neat job and much quicker too.
 Post subject:
PostPosted: Sun Mar 12, 2006 9:09 pm
Cheers for that, I'll have a look next time I am in the electrical shop!
chez
