It is currently Fri May 25, 2012 10:09 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 16 posts ]  Go to page 1, 2  Next
PostPosted: Wed Nov 09, 2011 6:57 pm
The handle on my UPVC window is just turning and sounds a bit like a ratchet grabbing and slipping , I thought it was the handle but it looks like its the mechanism inside the window just spinning round , how do I open the window to repair it ?
PostPosted: Wed Nov 09, 2011 9:35 pm
Has thanked: 18 times
Been thanked: 64 times
A few methods could used but need more info.Whereabouts is it ? Is it accessible from outside for example ? Can you deglaze a window if required ?
PostPosted: Thu Nov 10, 2011 12:13 pm
Its one of the upstairs bedroom windows , its only the small top push out window , It could be deglazed from the inside
PostPosted: Sat Nov 12, 2011 9:35 pm
Most windows can be deglazed from inside but can you deglaze one ? No point in me saying deglaze and do xyz if its out of your skills range.
PostPosted: Mon Nov 14, 2011 9:29 am
Has thanked: 17 times
Been thanked: 58 times
How tricky is it to do this?
My sister-in-law has a bathroom window with the same problem.
Is it easy to tell which types can or can't be de-glazed from the inside?
If at first you don't succeed - remove all evidence that you tried.
PostPosted: Tue Nov 15, 2011 9:14 pm
Thinking about this - wouldn't it be easier to drill out the lock on the handle in order to get to the spag?
PostPosted: Tue Nov 15, 2011 9:56 pm
The part that has failed is independent of the handle so by drilling the lock out on the handle means you ruin a perfectly good handle for no reason.
If you deglaze the window you can drill through and maniuplate the slider back.
PostPosted: Tue Nov 15, 2011 11:07 pm
If the spag is shot then yes, this would be a waste - but it the handle lock is faulty / spindle rounded out causing the jam it would work.
PostPosted: Tue Nov 15, 2011 11:37 pm
Jack Of All Trades
Has thanked: 27 times
Been thanked: 55 times
Is this conflict of opinion helping the OP?...Seeing as he/she hasn't made any comment for a few days now, perhaps he/she has given up on getting any sound advice... :dunno:
By eck! ©
PostPosted: Wed Nov 16, 2011 12:00 am
Probably - but it would be nice if anyone searching for a similar solution in the future finds a thread with answers / suggestions.
PostPosted: Wed Nov 16, 2011 4:39 pm
The spindles never round out as the part on the espag they interact with is always made from a cheap alloy that disintergrates hence the grinding noises.
Its pretty much the same thing that happens on door mechs when the door is out of alignment and the mech has to try and overcome all the friction thats created.They just give up at the weak alloy part everytime.You get the odd ones that have brass parts but very very few and far between.
PostPosted: Wed Nov 16, 2011 8:47 pm
Odd. Although I've only done a few dozen of these I'd say it's half and half spag and spindle wearing.
If the replacement handles supplied by toolstation are anything to go by, the spindles are made of something just slightly stronger than marzipan. :lol:
PostPosted: Thu Nov 17, 2011 12:28 am
If you have done a few why do you ask in an earlier post for advice on how to do it ? You only have to look at a locking handle spindle to tell it is much stronger than the espag mech itself, never seen a locking handle with marzipan type metal only locking mechs.
PostPosted: Thu Nov 17, 2011 8:21 am
:roll:
I didn't.
I was asking about deglazing a unit.
If the spindle / spag is rounded out you can usually access it, but if the lock has jammed and you can't get the handle to move then I wondered how easy it was to deglaze.
PostPosted: Fri Nov 18, 2011 5:41 pm
Ive still no luck getting the window open.
Users browsing this forum: village idiot and 6 guests
