It is currently Fri May 25, 2012 10:05 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Sat Nov 26, 2011 5:27 pm
Has thanked: 1 times
OnlyMe wrote:
No difference. I had actually misread your original post :sad:
Swapping the double socket at the back of the cooker for another cooker switch with a built in socket is IMHO a suitable way to proceed. Use the socket with a 3A fuse for the hob ignition.
No worries.
And thanks, but what about the advice i had ref option 2 (on original post):
"Advice #2 man says 4KW needs to be dedicated & not have anything else running off it as well - albeit the gas ignition is a small load and only used infrequently."
Is that being over-cautious then & it is al-right to do that (effectively Option #1 on orig post)?
PostPosted: Sat Nov 26, 2011 5:38 pm
Has thanked: 7 times
Been thanked: 66 times
Advice #2 man is probably mixing up or does not understand the electrical regs.
PostPosted: Sat Nov 26, 2011 5:50 pm
he is a sparky to be fair but didn't "see" the job & so I may have confused him with bad terminology
So, just to be clear before i fry Mrs RSB: :angryfire:
I use the 6mm feed from the cooker control unit (one above the worktop with a red rocker switch and a 3 pin socket) see link below
and wire that to ano one just the same underneath.
i.e. One like this:
http://s7g3.scene7.com/is/image/ae235/23484_P?$p$
that is 3A rated and then hard wire the oven to the supply side and plug in the gas hob ignition.
Lastly, what size / rating cable do i use to the oven plse?
PostPosted: Sat Nov 26, 2011 5:58 pm
Has thanked: 166 times
Been thanked: 614 times
From the red switched unit that you linked to to one of these.
http://www.toolstation.com/shop/Electri ... 633/p87053
Then to the twin oven.
PostPosted: Sat Nov 26, 2011 6:03 pm
That's not what "OM" is saying above though is it ?
So if i go with one of these:
http://www.toolstation.com/shop/Electrical/White+Wiring+Accessories/Cooker+Outlet+Plate+45amp/d190/sd2633/p87053
under the worksurface & behind the oven,
have i to get a completely different feed into a 3 pin socket for the gas hob from somewhere else?
Confuddled (again) sorry.
PostPosted: Sat Nov 26, 2011 6:15 pm
You have
on the wall feeding a double socket behind the cooker. You then replace the double socket for http://s7g3.scene7.com/is/image/ae235/23484_P?$p$ and wire the oven into the cooker terminals and plug the hob ignitor into the socket. Simple.
PostPosted: Sun Nov 27, 2011 12:09 am
Cheers OM.
Seems a lot simpler than channeling out ano feed for a separate socket.
What cable (I know it'll need to be 3 core) do I need though from the lower socket to the oven?
Doesn't need to be 6mm into the oven as well does it?
PostPosted: Sun Nov 27, 2011 9:15 am
If the oven manufacturer has not specified what sort of cable to use then I would use 2.5mm butyl flex eg http://www.tlc-direct.co.uk/Products/CA ... ash50.html
That is rated at 25A and your oven will only draw 17.4A
For this message the author OnlyMe has received gratitude : realstokebloke
PostPosted: Mon Nov 28, 2011 12:26 am
Cheers OM.
Looking back at the above (I think) i still have two slightly contradictory options but thanks anyway - also for the flex info.
Cheers again.
Users browsing this forum: OnlyMe and 20 guests
