Page 1 of 1
[ 2 posts ] |
| Author |
Message |
dennell
Posted: Sun Jan 08, 2012 10:16 am |
| Newly registered Member |
Joined: Sun Jan 08, 2012 9:51 am Posts: 1 Has thanked: 0 times Been thanked: 0 times
Hi
i have bought some 50mm polystyrene insulation boards to go in my cellar as my floor in the living room is cold. after talking to people i have been told to install with a gap between the board and the floor to create a barrier of air making it even warmer??? Is this right? how big a gap?
Also should i be filling gaps between the floor boards as well under the carpet?
| Top |
jozeffo
Posted: Sun Jan 08, 2012 1:40 pm |
| Senior Member |
Joined: Tue Dec 02, 2008 7:52 pm Posts: 2448 Location: South London Has thanked: 58 times Been thanked: 272 times
The answer depends on whether or not the space created will be airtight. If there are draughts running through under the floor areas, where there are airbricks, for example, then I would insulate directly under the boards or you will be wasting your time.
| Top |
register or
log in
Page 1 of 1
[ 2 posts ] |
