It is currently Sat Jan 20, 2018 3:21 pm
Visit Thermo worx
 Post subject: Under cabinet lighting
PostPosted: Sat Jul 15, 2017 9:25 pm
Has thanked: 5 times
Been thanked: 1 times
Hi
I've moved into a house which was wired up for under cabinet lighting in the kitchen, but was never installed. Would quite like to finish the job, but don't really know what I need to complete the job and how easy it will be.
Attached is a picture of the black boxes under the cabinets. There is already a light switch which we are told are for the under cabinet lighting, so I am assuming I just need the actual lights?
I've had a look for under cabinet lighting and most appear to come with a plug so not sure where to look.
Any assistance would be greatly appreciated.
PostPosted: Sat Jul 15, 2017 9:33 pm
Has thanked: 36 times
Been thanked: 1153 times
I just looked on line, there are lots of lights that are designed for "under cabinets" that do not have a plug. (What i like you may not, so it's your choice)
You would just need to connect which ever light you buy to the junction box you have. (You did take the lid off of the junction box, didn't you?)
For this message the author someone-else has received thanks - 2: multiman, Provaci
PostPosted: Sat Jul 15, 2017 10:03 pm
Has thanked: 696 times
Been thanked: 28 times
Most under cabinet light don't have plug some do send us a link and we can confirm if there is no transformer you can cut plug and wire in direct to find live you place common wire onto earth and the other wire on to blue or black the one that gives 230v will be your live.
For this message the author multiman has received gratitude : Provaci
PostPosted: Sun Jul 16, 2017 12:27 am
Thank you both. Attached is a questionable sketch of the layout of the kitchen (measurements in cm). I'm looking at different options such as getting a couple of these:
http://cpc.farnell.com/unbranded/20311/gabi-4-way-led-under-cabinet-light/dp/LA06162
But not sure whether these would work or give enough light?
PostPosted: Sun Jul 16, 2017 12:53 am
The lights you have linked to have a "wall wart" power supply, which must be plugged in. So those lights are of no use to you in this instance.
(A wall wart, is Image so you can't "cut the plug off")
PostPosted: Sun Jul 16, 2017 8:31 am
If you really want to use these then you can add a plug by running wire from junction box to socket and then plug lights in
PostPosted: Sun Jul 16, 2017 8:41 am
No strong desire to use those particular ones, just looking at LED strip lighting as think this will look best. Would these work better?
https://www.simplelighting.co.uk/230v-led-link-lights-various-sizes/
Sorry, as you might gather I'm a novice at these things.
For this message the author Provaci has received gratitude : multiman
PostPosted: Sun Jul 16, 2017 9:08 am
They do not have a "wall wart" so yes you could use them.
