It is currently Wed Jan 17, 2018 1:23 pm
Visit Thermo worx
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
 Post subject: ULTI Dimmer Light System
PostPosted: Sun May 14, 2017 9:24 am
Has thanked: 4 times
Been thanked: 4 times
I inherited a 2 Gang ULTI Dimmer Light system in my front room 3 years ago when I moved into my house, I still love it but I want to install Philips Hue, when I put one bulb in it just started flashing the other halogen bulb switched itself on but very dim.
I have no instructions (thanks previous owners) and the manufacturers website only has the brochure for this system so I don't know if the Hue is compatible, so I'm thinking I will need to swap out the current ULTI dimmer with a standard switch as I do not want to blow my new Hue lights which cost £50 each. So I opened up the ULTI panel removed to reveal cabling only to find 4 sets of live wires connected to the back.
I'm assuming this unit needs its own power source but why are there 2 lives going into one?
Can anyone give me some guidance or send me the instructions so I have a better idea of what needs to be done.
Darren
PostPosted: Sun May 14, 2017 10:19 am
Has thanked: 36 times
Been thanked: 1149 times
:dunno: Only a guess.
Turn the mains OFF!
Put some coloured tape on ONE of the single brown wires, (so you know it was a single) connect it to the double brown wires.
Turn the mains back on
Does one of the lights come on full brightness?
Turn mains OFF!
Put single brown back where it was.
Put switch back.
Type here the out come.
PostPosted: Sun May 14, 2017 11:05 am
Has thanked: 160 times
Been thanked: 5 times
Switch off electric lift up wires markings underneath take another pic with wires up thanks
PostPosted: Sun May 14, 2017 11:21 am
@someone-else what does it mean if one light stays on? I'm worried about doing your suggestion.
@sajeel there are no markings at all, all brown are going into unit, all 4 earthed to metal backing and 4 neutral terminated using terminal block
PostPosted: Sun May 14, 2017 11:25 am
I can see writing if you want me to help then get me pic so I can see what is going on
PostPosted: Sun May 14, 2017 11:26 am
Also pic of neutral and earth will help thanks
Turn the mains OFF!
Turn mains OFF!
Put switch back.
Please don't ask people to guess with electrics it's too dangerous and could go bang
PostPosted: Sun May 14, 2017 11:35 am
Does this help?
PostPosted: Sun May 14, 2017 12:09 pm
My suggestion is perfectly safe, otherwise I would not have posted it.
The guess is that the light will stay on.
After seeing your other picture, the light will stay on, there will be no bang, it will be perfectly safe. (The guess was will the light stay on)
I can also answer your question.
What you have is a 2 gang dimmer switch. (Ok, its a "fancy" / all singing one)
When it is switched to full brightness your Phillips lamp is getting a switched ac supply. It is expecting a constant ac supply.
If you want to use your Phillips lamps all you need to do is change the existing dimmer switch to a 2 gang on / off switch
e.g. Image
The reason you have 2 brown wires in 1 terminal is that:
Normally lights are "looped in" at the ceiling rose.
In your case they are "looped in" at the switch.
To "loop in" you have a live in, and a live out. Both in the same terminal.
In your case they used the terminal on the switch. (This is also used to supply the two lights you have)
PostPosted: Sun May 14, 2017 1:06 pm
Thanks @someone-else
Ok I bought a 2 gang on/off before reading as I suspected I needed to do this.
So as the "loop" is at the switch I need to separate the 2 connected to the single "L" and put in each 'L' of the new switch.
Do I then put Load 1 in left switch to L1 and the other to L2 on right?
Back of new switch;
PostPosted: Sun May 14, 2017 1:29 pm
@someone-else would you like to answer this by the way are you a qualified eletrician I have been doing electric work for years
PostPosted: Sun May 14, 2017 1:39 pm
Know let me explain there is two way of wiring in the UK we normally take live feed to light and bring switch wire down this is safer as you only have 115v in light unit, in America and Europe countries they take live feed to light unit switch it there and feed to light this was old school method in uk a long time a go.
The blue wires are neutral terminated as are the earths, the live supply is live feed and the load 1 and load 2 is lighting connected to those.
Both brown wires should have 230v on them after testing by using clamp clips and a meter never touch live wire you would place one on to neutral and one on to live then once confirmed both have voltage you would place one live into common and light you want to control in to l1 and repeat for other side.
PostPosted: Sun May 14, 2017 1:42 pm
Back of new switch;
After checking both are live you would place brown wires into l and one of the load wires into l1 each side if you put into l2 no harm will be done just that light will be on in off posistion
PostPosted: Sun May 14, 2017 2:34 pm
Approved Electrician
Has thanked: 147 times
Been thanked: 520 times
Correct.
I don't know much about the Phillips Hue (I have spent more time with the LightwaveRF systems), but a quick Google suggests that the Hue uses it's own dimmer switch - either a battery remote controlled one or one that is a replacement for the existing dimmer switch.
Either way the existing dimmer needs to go.
PostPosted: Sun May 14, 2017 2:39 pm
Thanks for suggestions everyone finally got it going with new switch.
Once again thank you
For this message the author dgulliver has received gratitude : sajeel
