It is currently Wed Jan 17, 2018 3:16 pm
Visit Thermo worx
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun May 14, 2017 3:00 pm
Has thanked: 36 times
Been thanked: 1149 times
dgulliver wrote:
Thanks @someone-else
So as the "loop" is at the switch I need to separate the 2 connected to the single "L" and put in each 'L' of the new switch.
Do I then put Load 1 in left switch to L1 and the other to L2 on right?
Back of new switch;
Sorry, no. If you do that you are "breaking" the live loop in (well the loop out actually) so one of the lights would work, the other would not work.......and neither would some other lights in your house.
What you need to do is.
Electricity off first.
Put coloured tape (not blue) on each of single browns. This is so you know that they are single, and the other two browns (no coloured tape) are joined together.
(You will also need a short piece of wire the same size as what is there 1.0mm or 1.5mm)
ONE (Doesn't matter which one) single brown in the LEFT switch terminal L1
The other single brown in the RIGHT switch terminal L1
One of the joined browns in the LEFT switch terminal L
The other joined brown in the RIGHT switch terminal L
IMPORTANT PART
You now need to add a link wire (Short piece of wire) between The L on the left and the L on the right
You will end up with.
Nothing in either switch L2
1 wire in each L1
2 wires in each L (one will be a link from one to the other)
Put switch back, don't squash any wires.
Switch mains back on, happy days.
:oops: I stopped typing to have a quick bite.
For this message the author someone-else has received gratitude : sajeel
PostPosted: Sun May 14, 2017 3:03 pm
Now what you need to do is to make a short video, so we can see the lamps change colour etc :wink:
PostPosted: Sun May 14, 2017 4:27 pm
Has thanked: 4 times
Been thanked: 4 times
Will do, camera not picking the colour in this light, when it gets darker I will do it
For this message the author dgulliver has received gratitude : sajeel
PostPosted: Sun May 14, 2017 5:40 pm
Has thanked: 160 times
Been thanked: 5 times
How did you end up wiring in the end just curious if someone-else was correct of wiring was looped at switch ?
PostPosted: Sun May 14, 2017 8:46 pm
I put the 2 looped into one switch then linked to second. Then put one in L1 of on switch then L1 of other.
PostPosted: Sun May 14, 2017 9:20 pm
That will work I just don't believe it was loop in loop out I believe it was two feeds but we'll leave it that
PostPosted: Sun May 14, 2017 9:49 pm
Sorry but you believe wrong, it is loop in loop out at the switch.
PostPosted: Sun May 14, 2017 10:12 pm
You may be right bit without measuring we will never know so let's call it truce
PostPosted: Sun May 14, 2017 10:47 pm
Don't need to measure anything, only need to look.
I am trying to help you.
PostPosted: Sun May 14, 2017 11:13 pm
Approved Electrician
Has thanked: 147 times
Been thanked: 520 times
sajeel wrote:
Know let me explain there is two way of wiring in the UK we normally take live feed to light and bring switch wire down this is safer as you only have 115v in light unit, in America and Europe countries they take live feed to light unit switch it there and feed to light this was old school method in uk a long time a go.
The blue wires are neutral terminated as are the earths, the live supply is live feed and the load 1 and load 2 is lighting connected to those.
Both brown wires should have 230v on them after testing by using clamp clips and a meter never touch live wire you would place one on to neutral and one on to live then once confirmed both have voltage you would place one live into common and light you want to control in to l1 and repeat for other side.
You are making an awful lot of noise and spouting a lot of spherical hairy objects.
You say that there are only two way's of wiring a lighting circuit in the UK.
I know of four pretty much standard ways of wiring UK lighting circuits.
For this message the author OnlyMe has received gratitude : someone-else
PostPosted: Sun May 14, 2017 11:15 pm
I didn't want to say what you just said, but it is true.
PostPosted: Sun May 14, 2017 11:23 pm
Look im not here to argue I have done wiring long enough to know what I am talking about, have managed to troubleshoot jobs other electrician have been unable to do.
By the way I am not making noise,
There are two main ways the other ways are associated with these two methods so let's end that there unless you want to list your methods so we can discuss ?
I said we wont ever know so call it truce but you lot still want to argue, I will be not be intimidated by you so bring it on if that's the way you want to be
PostPosted: Sun May 14, 2017 11:44 pm
You need to chill out and relax. Your last post don't sound like someone who is not here for an argument.
"I will be not be intimidated by you so bring it on if that's the way you want to be"
has to be the worst post I have ever seen on this forum.
PostPosted: Mon May 15, 2017 12:01 am
Oh well, if you stopped trying to argue and gang up with your buddy then there was no need so you chill out and relax have a cup of tea or coffee
PostPosted: Mon May 15, 2017 1:07 am
Guys,
Everything is working now thanks to everyone's input, I came here for assistance not a slanging match.
Here is my Hue on "Party Time" triggered through IFTTT.
https://drive.google.com/open?id=0BwdoU ... GFNb1hFMGs
Again thank you all for your contributions
Darren
