It is currently Wed Jan 17, 2018 11:19 am
Visit Thermo worx
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
PostPosted: Sun Oct 15, 2017 12:16 pm
Hello,
Has anyone had a problem with the Router mounting plate on the Router Table Module TWX7 RT001 .
The plate is only 1.7mm thick and moves which causes the router bit to move when cutting and causing chatter in the cuts.
I have made a really bad video showing the problem
https://youtu.be/aQNZK7EtlbA
PostPosted: Sun Oct 15, 2017 1:07 pm
Has thanked: 950 times
Been thanked: 913 times
I don't know anything about that particular setup, but can you make a replacement one out of aluminium?
PostPosted: Mon Oct 16, 2017 8:22 am
Yes I guess, shouldn't have to really
PostPosted: Mon Oct 16, 2017 9:54 am
Has thanked: 453 times
Been thanked: 1518 times
Would this upgrade fit? It is for a different Triton model though http://www.toolsparesonline.com/product ... e-kit.aspx It might be worth contacting them to see if there is an upgrade kit for your table.
Painting with BIN
PostPosted: Mon Oct 16, 2017 10:50 am
Has thanked: 643 times
Been thanked: 1818 times
how much material are you trying to remove at once??
chattering can be caused by overloading the cutter or unballanced or cutter working loose
if you try to remove say 3mm x40mm wide off material how does it perform ??
PostPosted: Mon Oct 16, 2017 11:17 am
If you look at Piccyman's video you can see the flex in the base allows a degree of movement on the cutter. This woudl cause the cutter to bounce against the work and cause an irregular cutting pattern, far from the accuracy needed in table router work. Would it be possible to fashion a reinforcing plate to sandwich between the router and the table mounting plate? A bit of ply would probably do it.
Painting with BIN
PostPosted: Mon Oct 16, 2017 11:27 am
.25mm on a piece of 2x1 pine, look at the video to see the movement, hardly any pressure to move the router
PostPosted: Mon Oct 16, 2017 11:29 am
I was thinking of drilling through the plate using the same fixings for the plastic base plate thats removed to fit on the router table.
That would give 2 extra fixing points to the plate on the plane that moves, if that makes sense.
PostPosted: Mon Oct 16, 2017 11:31 am
Anything that beefs it up will probably do the trick :thumbright:
Painting with BIN
PostPosted: Mon Oct 16, 2017 12:32 pm
i personally would disassemble the router from the table check each components is clean and a good fit and all the plastic bits are fully clicked home
PostPosted: Mon Oct 16, 2017 12:42 pm
another thought
if you are adjusting via a fine control mechanism are you also using the plunge lock mechanism ??
PostPosted: Mon Oct 16, 2017 12:43 pm
Thats not the problem, its the mounting design thats poor, its clean and all the parts screw in ok, no clips or anything odd fitting.
The only other part that is incorrect is the adjusters for the centre cover ring, the recess cut into the table is slightly too deep and the grub screws at just at a point of falling out, poor manufacturing / and design, its an easy fix.
PostPosted: Mon Oct 16, 2017 12:45 pm
You need to look at the videos
PostPosted: Mon Oct 16, 2017 1:21 pm
in the second video the plunge lock lever doesnt look to be in the locked position :dunno:
PostPosted: Mon Oct 16, 2017 1:30 pm
In an ideal world no you shouldn't, but I often seem to end up modifying kit in some way. Depends if the rest of it does it's job OK.
